Although i don't adjust mine often, the fact i can move the pedals is wonderful.
With the memory feature two drivers can each save their setting. if, you ever let somebody else drive.
My 2005 X EDDY B pedal and seat controls are on the door with 2 memory settings.also there is switch on dash so you can overide the programed settings.
My wife loves driving big trucks, as she always puts it, chicks in trucks are sexy. Of course she is also 5.5 so the adjustable pedals come in handy. It's a nice break from here Escape every once in a while. Given her druthers she still prefers me to drive when we go somewhere though.
Ok..and also you will need to change the lower dash with one that contains the switch unless if you want to wire up a toggle switch instead. I'm going to try this over the weekend and ill post pics of the progress to help.
My 03 has a little plastic knock out where the pedal switch would go, so if I added it I would just have to remove that plug..
Wonder if it's really a knockout, vs. an outline in the dash panel where the switch should go?
I see many of the XLT Ex have the panel with the outline of where the switch goes like this...
It's a knockout with the electrical connector for the switch (if there was a switch) attached to the back of it.
That's where I mounted the switch that powers the back-up camera I installed on my old truck. I tapped into the wire that was attached to the back of the knockout to power the switch.
WOW. Do you have a picture of the backside of the panel that hold the 4x4 switch/electric defroster/backup disabled switch(es)??
I want to install some LEDs and switch(es) into the extra space on that panel, and don't want to just TRY to pry off the cover plate and end up breaking some tab(s)..
Here you go, if you need other shots let me know... I have a spare in the garage
