Rear fuel pump dead on 91 F250, cant figure out why - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 07-24-2014, 07:48 PM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
I take it you are saying that you grounded pin #6 of the self-test plug with the key on and the fuel pumps did not run.
If that is so did the fuel pump relay click when you grounded pin #6?
If not did the EEC Power relay click when the key was turn to run?
If the EEC Power relay did click when the key was turn to run did the red wire going to all the fuel injectors have power on them and light a test light?
If the fuel pump relay did click when you grounded pin #6 and the fuel pumps did not run then you either have a bad fuse link at the starter solenoid on the fender and no power on the yellow wire feeding the fuel pump relay or you have a tripped fuel shutoff switch or a bad selector switch at the dash or bad wiring to the pumps or of course bad pumps.
  #32
Old 07-24-2014, 08:06 PM
cagedog cagedog is offline
cagedog is starting off with a positive reputation.
Relay clicks when key is on.. Yellow wire has power on relay no burned links..red wires on injectors have power.. Inertia switch good.. Can you bypass fuel selector switch in dash? No power to either pumps..
  #33
Old 07-24-2014, 09:39 PM
subford's Avatar
The frame pumps power does not go through the fuel selector switch in dash so if it does not have power then it is not the fuel selector switch in dash.
Have you tried resetting the fuel shutoff switch?
Have you checked for power at the fuel shutoff switch with the key on and pin #6 grounded of the self-test plug?
  #34
Old 07-25-2014, 12:03 PM
Grounded pin 6. No voltage to fuel shut off switch.. Thanks for your help and Patience.. What would come next?
  #35
Old 07-25-2014, 12:43 PM
Quote:
Also... I got under the truck and there is voltage to high pressure pump and voltage at yellow wire to fuel tank.. But to power at shut off switch? Doesn't make much sense to me...any help.is appreciated
  #36
Old 07-25-2014, 01:37 PM
Update...spent about 1 hour with my test light.. Something changed..was getting power at yellow ..wht with green strip and red on relay...now only yellow is hot...also when I tested earlier I had power to fuel injectors... Now I don't.. Grounding pin 6 makes relay click but no pumps Also check engine light that is normally on while key is in on position.. Is no longer on.. While fumbling with relay...I did get fuel pumps to flicker on for a brief second.. Current situation.. Power at fuel pumps..but not turning on... No power to injectors.. Relays only have power at one wire each...yellow on one relay...black w yellow stripe on other. What am I missing?
  #37
Old 07-25-2014, 06:06 PM
subford's Avatar
If the fuel pump relay clicks when you ground pin #6 with the key on then you should also have power to the fuel injectors, it is the same red wire circuit coming from the EEC Power relay.
Also if you have power to the high pressure pump on the frame then you would also have power at the fuel shut-off switch.
  #38
Old 07-25-2014, 07:48 PM
Ended up being a connection on the relay.. Blue wire that splits into 2 red wires by fusable link on the plug.. Still no power at fuel cut off switch.. My best guess is it was bypassed at some point.. Everything seems to be working again...for now...thank you!
Fuel returning to front take when rear tank selected? Dean06919 1987 - 1996 F150 & Larger F-Series Trucks 3 07-20-2015 04:36 AM
'99 F350 In Tank Fuel Pump modmxz 1999 - 2003 7.3L Power Stroke Diesel 9 05-18-2014 10:30 PM
Zero fuel pressure... GotThreeOfThem 1987 - 1996 F150 & Larger F-Series Trucks 9 07-10-2013 05:58 AM
84 f250 not hearing fuel pump lovinmytruck 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 19 02-21-2010 09:56 AM
Fuel Pump Woes LastTudor 1987 - 1996 F150 & Larger F-Series Trucks 8 03-26-2009 11:05 AM
Tags
1987, 1996, 2002, 250, 91, deisel, f150, f250, ford, fuel, located, pump, rear, start, volts
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
