Rear fuel pump dead on 91 F250, cant figure out why - Page 2 - Ford Truck Enthusiasts Forums
Old 03-07-2012, 08:59 PM
Bootlegger's Deluxe's Avatar
Bootlegger's Deluxe Bootlegger's Deluxe is offline
Bootlegger's Deluxe is starting off with a positive reputation.
ok, so ground number 6 to the battery ...
Old 07-10-2014, 08:13 PM
cagedog cagedog is offline
cagedog is starting off with a positive reputation.
I had same problem.. Grounded pin 6.. Which gave pumps power ..but they wouldn't prime the system..would only start with ether ..grounded pin 4.. It gave me power..primed the unit.. But the truck ran pretty rough...but did start onnits own... Grounded pin 2 (test out),,truck starts idles revs and seems to run great. But caused a check engine light.. What's the next step?,,I'm no mechanic. But seems like you guys are helpful and I've gotten further from reading than the last 2 mechanics... I'm going to be a pro now I've become a member...lol. Thanks for any help you can give
Old 07-10-2014, 10:08 PM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Quote:
Sounds like the small black wire with a green stripe at the NEG battery post has a bad connection or is not there.
Old 07-10-2014, 10:17 PM
Quote:
Hmmm. The only black wire I see on NEG goes across the firewall to driver side then goes in the cab. Where should this black/green wire be going?
Old 07-10-2014, 10:20 PM
I also went thru the blink codes.. Came up with 87. 95. Primary and secondary fuel pump circuit failure
Old 07-10-2014, 10:27 PM
I'm sorry...my truck is a f450 with the 7.5 efi. Not sure if that's a game changer... But I was excited that grounding the pins made it run.. Like I said. 2 previous trips to shatty mechanics resulted in me towing the truck home ...
Old 07-10-2014, 10:43 PM
subford's Avatar
It should run from the NEG post of the battery to pins #40 & #60 of the EEC Computer.
Old 07-10-2014, 10:47 PM
Is this the same for 7.5? I'll check tomorrow to see if that's where it goes..
Old 07-10-2014, 10:54 PM
[QUOTE=cagedog;14498153]Is this the same for 7.5? I'll check tomorrow to see if that's where it goes..[/QUOTwhere is the EEC in the f-450? I know that's probably a dumb question ...but like I said...I'm no mechanic...lol
Old 07-11-2014, 08:15 AM
subford's Avatar
Yes the wire should be the same, there should be a total of two small wires and one large wire. Left diagram below.
You might also want to run a 10GA wire from the NEG post to the Body (not the frame).
The EEC Computer is behind the the LH (drivers side) kick panel. It will unplug from under the hood and is removable from inside the cab.
Left diagram for a gas truck:
EEC Computer plug, 10mm wrench size bolt in in plug:
EEC Computer plug to show locations of pin 40 & 60 ground pins:
Old 07-11-2014, 09:02 AM
You previously said pin 40 and 60.. But this doesn't show that many..lol. EEC case ground pin 20?? I have her tore apart now. And your help is much appreciated
Old 07-11-2014, 09:34 AM
eec
OK..I'm sorry. Found pin 20-40-60. One is going to the fender for ground...the other 2 black wires with yellow stripe go into the harness.. I used my test light and grounded one end..probed with the other...and its lighting as if it has power ..
  #28
Old 07-11-2014, 09:46 AM
subford's Avatar
The wires going to pin #40 & #60 should never have power on them.
I up-dated the numbers in the above diagram for you.
By the way that is a green stripe, not yellow.
Case ground does go to the fender, #20.
  #29
Old 07-11-2014, 10:13 AM
You are the man!!! I found the culprit.. Thank you so much for your help!!!! There was a third ground wire that was broke off.. From the negative post there was a clip with 2 wires...one was broke...once again thank you tons!! Now to put it all back together.!!
  #30
Old 07-24-2014, 06:36 PM
OK...so a few weeks back you guys helped me finding to issue described on this thread.. I used the truck a few times...worked great.. Its sat for a couple weeks..went to fire it up ..and once again no fuel pumps...I really needed to.move the truck so attempted to ground the pin on obd test plug to bypass...but now I'm getting nothing there either..all relays new..good grounds everywhere.. Bypass will not over ride?? Helppppp...lol.
'94 460 dual tank gas-fuel moving from rear tank to front? Ex-ChevyOwner Fuel Injection, Carburetion & Fuel System 2 10-07-2015 10:14 PM
Fuel returning to front take when rear tank selected? Dean06919 1987 - 1996 F150 & Larger F-Series Trucks 3 07-20-2015 05:36 AM
'99 F350 In Tank Fuel Pump modmxz 1999 - 2003 7.3L Power Stroke Diesel 9 05-18-2014 11:30 PM
Zero fuel pressure... GotThreeOfThem 1987 - 1996 F150 & Larger F-Series Trucks 9 07-10-2013 06:58 AM
84 f250 not hearing fuel pump lovinmytruck 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 19 02-21-2010 10:56 AM
Tags
1987, 1996, 2002, 250, 91, deisel, f150, f250, ford, fuel, located, pump, rear, start, volts
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
