79 400 build up
#32
It cracked on the opposite side I had all the bolts in - go figure. from the passenger top bolt to an inch from the starter.
Everything's together now, looks good. Have to make one more parts run for a few misplaced bolts. All that's left to do is pluming and wiring. Hope to crank it around noon.
#35
on
Should be similar to this:
https://www.ford-trucks.com/forums/1...3-f-100-a.html
But check out the wiring schematics for yours here:
1973-1979 Ford Truck Wiring Diagrams & Schematics - FORDification.net
#38
Wow that is an amazing build. I want to do a build like this to a 460 then put it in a nice f150 or f250 from down south and completley rebuild the truck itself too.
I dont know much about these at all and will be having the engine done by a buddy of mine who rebuilds alot of engines. When you get the chance could you make a list of all of the parts you replaced/modified and what the manufacture and model is please ? (if you don't mind)
Thanks and can't wait to see the video !
#39
#41
#44
#45
Loaded up two videos, one break in and the other backed down to idle. Still need to set base timing and mess with the mechanical springs and stop bushing.
http://s1251.photobucket.com/albums/...9silverstreak/
