79 400 build up
on
I went with Quick fuel because all I hear are good things about them. Basic design is basically the same as a holly. I was never fond of Edlebrocks's design, besides the accel pump. I also got the annular boosters with the QFT. I'm sure Holley now makes a carb identical to the quick fuel, I just wanted something a little different.
I'll be sure to post a video.
Didn't get as much done as I'd like too, but I think I'm over the hill. Had to pull it to a stop due to breakage of my craftsman torque wrench, a nut was flopping around in the handle, and then the handle came off. All I like now is ignition wiring, tach wiring, starter, radiator, and carb install/ plumbing.
Make sure your initial timing is set correctly. If you have it too advanced, you'll be running hot and pinging but you won't be able to hear it because you're gonna have it at 2k breaking in that cam.
Prime that oil pump with a drill!
Pour a little gas down the carb to get her started.
Have a fire extinguisher ready.
Smile, you're kickin *** man! You gonna put a start up video on youtube?
Set the motor back in, every thing lined up. Had to hold off running bolts to go to work. I reckon tomorrow I'll finish it up.
It's a crappy idea but once I get it togeather, I'll run the crack with a dremel and fill it with some jb weld, That might hold off until my ZF 5 swap... All the more reason to get the new tranny quicker
#29
on
Hate to bring this up but if you didn't have the torque converter installed in the transmission fully and then tightened the bolts up so much as to break the case you have bigger issues now.
All that pressure that it took to break the case was being backed up by the transmission pump. While it is possible.... chances are that you damaged the pump.
I hope it didn't but from what I understand it doesn't take much....
#30
