4.9 efi valve cover gasket - Ford Truck Enthusiasts Forums
Old 03-04-2012, 10:13 PM
Vonn4.9efi Vonn4.9efi is offline
Vonn4.9efi is starting off with a positive reputation.
I need help finding a good video on how to replace my valve cover gasket on a 89 f150 4.9 efi 93000 miles. I can only find ones for other cars, and they dont show how to remove all the things on top of the cover. Thanks allot.
Old 03-05-2012, 01:09 AM
882tank's Avatar
882tank 882tank is offline
882tank is starting off with a positive reputation.
Buy a good Haynes or Chiltons manual. It's a pretty simple project even though the upper intake has to come off.
Old 03-05-2012, 08:42 AM
hotrod351's Avatar
hotrod351 hotrod351 is offline
hotrod351 is starting off with a positive reputation.
i did mine on my 90. when it came down to it, well it really wasnt that hard. the wire plugs will only plug into what there suppose to plug into. i remember you only have to remove the upper manifold section. it might help you if you take somme pictures on how the vacuum line go. it looks worse than it is.
Old 03-05-2012, 08:52 AM
dustybumpers's Avatar
dustybumpers dustybumpers is offline
doesn't play with idiots
dustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputation
Hardest part is removing the egr, But you can cheat, and just let it hang in the air
Old 03-05-2012, 11:12 AM
andym's Avatar
andym andym is offline
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
There are no special tools or tricks required. If you can remember which way to turn the wrench you're good to go.
Old 03-05-2012, 07:27 PM
Quote:
Alright sounds good. I have my chilton book, got it from the library today. The only things I have done by myself working on a truck is breaks, starter, fuel pump, oil change, spark plugs.
So You guys think I can handle this one huh? Im about to read this book all this week and maybe tear into it this weekend. Ill take the pictures, maybe you guys can get some lulzzz when I come on here bitching asking for more help lol.
Old 03-05-2012, 07:30 PM
We'll be here, you won't have any problem
Old 03-05-2012, 07:35 PM
FordOwnerJoey FordOwnerJoey is offline
FordOwnerJoey is starting off with a positive reputation.
Ive had to do it twice on my 87 300-six and i couldnt tell u how many times i had to take the upper and lower intake manifolds off. I could probably do it in about 20 mins now using an air ratchet. I can take some pics and show you what and where to take stuff off at
Old 03-05-2012, 07:47 PM
Quote:
That would be neat if you could highlight all the parts that need to come off. Without looking at my book yet Im not even sure I could tell You where the valve cover is. Is it the thing I pour oil into? Sorry for being such a newb, being a 26 yr old guy I feel pretty pathetic not knowing these things.
Old 03-05-2012, 07:54 PM
yeah, it might be blue (mine is painted red) but its where you pour the oil in. ill take pics tomorrow during the day light and post. Your going to want a new upper intake manifold gasket too so make sure you pick one of those up before you get the engine all torn down if thats your only vehicle. I also recommend some liquid gasket like RTV silicone, I think I used black but red is for high temp I believe. The first gasket I got was a cork/rubber/metal combination but it didnt last very long about a yr or so, I just redid it a few months ago and got another gasket and then put a bead of the silicone along the gasket facing down and then another bead along the bottom of the valve cover itself. Havent had any leaks since. I couldnt find a rubber gasket for it and I hate cork, so if you can find an all rubber gasket I suggest getting it instead of an all cork. Cork is cheap but its for a reason....
Old 03-05-2012, 07:56 PM
What are the things I should read about in this book?
upper intake manifold removal, and what else?
Old 03-05-2012, 08:06 PM
that and more importantly the order in which you torque the bolts back down. theres a certain pattern you go in both for the valve cover and the upper intake. My truck has already had the A.I.R. tube deleted so Im not sure if thats a problem or not.
Old 03-05-2012, 08:20 PM
882tank's Avatar
The A.I.R. tube is not an issue. Just be sure to pick up quality gaskets, and make sure the VC gasket has torque limiters built in.
Old 03-05-2012, 08:25 PM
I found the diagram for how to torque the bolts and the nm. What Ill do is take a picture of my engine asap and get it on here. And Ill let you put a red dot or whatever on all of the parts i need to remove and maybe label it for me. The book says remove this, this, this, this, but I dont know what that is or looks like lol. I have allot of reading to do.
Old 03-05-2012, 08:30 PM
ok we can do that too
Unknown engine ID help DrZoom 1987 - 1996 F150 & Larger F-Series Trucks 22 04-13-2015 01:58 PM
P0300 1996 F150 4.9??? 88PONY 1987 - 1996 F150 & Larger F-Series Trucks 2 11-27-2013 10:56 PM
4.9 Valve cover gasket.. help? Koch85F150 Ford Inline Six, 200, 250, 4.9L / 300 9 05-25-2013 09:24 PM
300 I6 - Removing EFI Intake manifold, how difficult? JoePhoto 1987 - 1996 F150 & Larger F-Series Trucks 10 01-12-2012 06:30 PM
How many HP and Torque in a 300 4.9L engine? Tepot Ford Inline Six, 200, 250, 4.9L / 300 8 04-02-2004 04:30 PM
Tags
49, 49l, 96, change, cover, device, differences, electronic, f150, ford, gasket, patter, vacumn, valve, video
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
