Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 03-04-2012, 08:28 PM
D-Rock D-Rock is offline
Garage is empty, add now
D-Rock is starting off with a positive reputation.
2007 Expy Starting issue
Looking for help - I experienced a no start with my 65k mile Expy. Here is what I am seeing and I think I may be having 2 issues at once. I went to leave my in-laws after dinner tonight and the truck wouldn't start.
The truck cranks fine, but won't start. I get no sound from fuel pump and no residual fuel pressure on the schraeder valve on the fuel rail. I checked the inertia switch and it was in the on position. I think this may be the fuel pump control module (it seems to be a common issue for Expys and F150s), but is there a known way to test these before replacing? I'd rather not drop $100 on a part that is not the source.
As if that wasn't a big enough pain, the starter will not disengage when I release the key - it keeps cranking, unless I turn to full off. I am assuming this is a shorted solenoid, but also wonder if it may be the ignition switch. Again, looking for any way to isolate which may be the culprit. FWIW, battery only 4 months old and is at 12+ volts. Also, ran a scan tool and there are no DTC codes.
Any help or thoughts are appreciated.
__________________
2007 Eddie Bauer Expediton - Wife's War Wagon - Stock, Stock, Stock
2004 SVT Cobra - my DD - and it's anything but stock
Tags
2007, expedition, fuel, pump, start
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
