Carb rebuild help!!! 1982 f100 - Ford Truck Enthusiasts Forums
Old 03-04-2012, 03:58 PM
jeserah's Avatar
jeserah jeserah is offline
jeserah is starting off with a positive reputation.
I'm about halfway finished rebuilding the carburetor on my f100, 300 straight 6. Problem is that there is a tiny ball bearing that is supposed to go somewhere, I think, but I can't figure for the life of me where it's supposed to go. The rebuild kit assembly page isn't any help at all. can anybody help me figure this out?
Old 03-04-2012, 05:22 PM
82f100460's Avatar
82f100460 82f100460 is offline
82f100460 is gaining momentum as a positive member of FTE.82f100460 is gaining momentum as a positive member of FTE.
look where the accelerator pump is. There is usually a ball that acts as a check valve there. Not sure what carb you have...I'm thinking of a Holley but it's the only place I can think of for a ball.
Old 03-04-2012, 05:29 PM
82f100460's Avatar
This is a picture of a typical holley acc pump ball check.
Old 03-05-2012, 01:20 PM
pd59 pd59 is offline
pd59 is starting off with a positive reputation.
I just rebuilt my yfa last weekend. I used these videos to help me out. Carter YFA Carburetor Rebuild Part 1 of 4 - YouTube
Carter YFA Carburetor Rebuild Part 2 of 4 - YouTube
Carter YFA Carburetor Rebuild Part 3 of 4 - YouTube
Carter YFA Carburetor Rebuild Part 4 of 4 - YouTube
I found these videos very helpful. I had never torn apart a carb bigger than one on a honda generator motor before, and I got my YFA done no sweat. Even covers adjustments as well. This guy sells rebuild kits for all kinds of carburetors, too. Hope this helps.
Old 03-05-2012, 08:13 PM
81-F-150-Explorer 81-F-150-Explorer is offline
81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold
Look at this diagram, it shows the check ball and the check weight.
There is a plastic hose that connects the accelerator pump diaphragm housing to the orifice where the accelerator pump check ball and check weight goes into.
1968 Ford F-100 Glovebox Spring Sidekick41 1967 - 1972 F-100 & Larger F-Series Trucks 2 03-17-2017 01:41 PM
56 Ford F100 master cylinder rebuild hooler1 1948 - 1956 F1, F100 & Larger F-Series Trucks 26 06-18-2015 10:11 PM
1964 Wiper Switch Rebuild Coldstoli 1961 - 1966 F-100 & Larger F-Series Trucks 15 05-05-2015 08:55 PM
Carb Rebuild meangenejr Fuel Injection, Carburetion & Fuel System 4 08-18-2004 06:11 AM
390 Head Gasket Question 222 PACman FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 5 04-25-2004 02:29 AM
Tags
150, 1982, 300, 82, breakdown, carb, carbuartor, carburetor, carter, f100, f150, ford, rebuild, rebuilding, truck, yf
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
