Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 03-04-2012, 11:56 AM
ReBilld's Avatar
ReBilld ReBilld is offline
Garage is empty, add now
ReBilld has a very good reputation on FTE.ReBilld has a very good reputation on FTE.ReBilld has a very good reputation on FTE.
Cab lights ?
Have any of you had your cab lights to leak before ? I think mine are on the '97 I just got. The night we brought it home on the roll back it was pouring rain and there was water dripping from the interior trim across the top of the windshield. Not sure if it's the cab lights or the windshield.
  #2 (permalink)
Old 03-04-2012, 12:49 PM
Midwest Dually's Avatar
Midwest Dually Midwest Dually is offline
1994 Ford F-350
My Garage
Midwest Dually has a good reputation on FTE.Midwest Dually has a good reputation on FTE.
It has been known to on an occasion. It is pretty easy to find the water marks though under the cab lights as compared to the seal around the window! Pop one off and share what you find!
__________________
- Chris -
1994 F-350 CC Dually : DRW 4x4 XLT, 97 7.3 DIT conversion, tuned, open pipe and modded!.
  #3 (permalink)
Old 03-04-2012, 02:09 PM
fordpride's Avatar
fordpride fordpride is offline
Never done with mods
1997 Ford F-250
fordpride is a splendid one to beholdfordpride is a splendid one to beholdfordpride is a splendid one to beholdfordpride is a splendid one to beholdfordpride is a splendid one to beholdfordpride is a splendid one to beholdfordpride is a splendid one to beholdfordpride is a splendid one to behold
My lights leaked and the water ran in the trim and was dripping on the pass. door
__________________
Mike. 97 F250 totaled 11/19/12 B.E.S.T. map Louisiana FTE Member Map
2012 Ram CC 1500 5.7 Hemi
Diablo sport trinity hemi fever tune, 87mm throttle body, BBK headers, HF cat, 14" magnaflow, AFE intake, 180* T-stat. All waiting for time to be put on.
When married you have two simple choices. You can be "Happy" or you can be "Rite" you can't have both
  #4 (permalink)
Old 03-04-2012, 02:20 PM
ReBilld's Avatar
Quote:
Mine was dripping on the 4x4 shifter and the pass. side floor. I figured it to be the lights more than the windshield. I'm gonna go out there in a little while and pull em off and see if I can tell where they have leaked and seal em up. I wanna get it out of my shop cause I gotta pull the trans on my Ranger, but I don't wanna leave it outside leaking.
  #5 (permalink)
Old 03-04-2012, 05:15 PM
ReBilld's Avatar
Went out and pulled off all the cab lights, but couldn't really say if they were leaking or not. I'll do a water test one day when it warms up, it's snowing right now.
  #6 (permalink)
Old 03-04-2012, 05:41 PM
mjonesjr's Avatar
mjonesjr mjonesjr is offline
mjonesjr is starting off with a positive reputation.
Maurice Jones Jr. FireAttack8
Go buy yourself new gaskets from your Ford dealer. They are about $5 each.
__________________
1997 F-250HD Extended Cab 4x4 7.3 Powerstroke
3" Down Pipe to 4" Exhaust (Stainless) ~ Tymar Intake ~ TS 6 Position Chip ~ HPOP Cross Over Line ~ Regulated Return ~ E-Fuel System ~ Intercooled ~ CCV Mod ~ Dana 60 Swap
  #7 (permalink)
Old 03-04-2012, 05:47 PM
nateairman's Avatar
nateairman nateairman is offline
nateairman is starting off with a positive reputation.
I had the same problem and found that the windsheild was leaking. Take the trim off on the inside at the top of the windsheild and take it for a burn. Found it was bubbling in right in the center.
Took the time to sand blast the outside fill, prime and paint to match this weekend. I have aslo ordered new cab lights as the previous owner had broke a couple in the under ground.
New windshield is going in this week. Hoping to have a dry cab.
The other place to check may be the top corners of the cab where the body seam is. One of mine may have been leaking there.
Good luck!
__________________
6637, 3" DP, 4" straight pipe, 7.3IC, Isspro gauges, bds 6" spring lift, 4.88, airbags, exhaust brake, Rosewood stage ones, PHP tunes, T500 waiting in the shop
  #8 (permalink)
Old 03-04-2012, 07:09 PM
ReBilld's Avatar
Gonna order the new gaskets tomorrow and the windshield is cracked so I'm gonna go ahead and have one put in. There is some rust at the top corners of the windshield so I might take it out myself, sand and paint, then have a new one put in.
Thanks guys!!!
  #9 (permalink)
Old 03-05-2012, 08:32 AM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
1996 Ford F-350
DIYMechanic has a great reputation on FTE.DIYMechanic has a great reputation on FTE.DIYMechanic has a great reputation on FTE.DIYMechanic has a great reputation on FTE.DIYMechanic has a great reputation on FTE.DIYMechanic has a great reputation on FTE.
Quote:
For that price I would put an extra $2 a light in it and get new lights. NAPA sells them for about $7 a piece.
__________________
--Nate "Just a redneck geek"
1996 F-350 7.3L PSD, 4x4, CCLB SRW, 3.55's, E4OD, EBPV Delete, 3" DP, Stock Tailpipe and Muffler, Riffraff 6637 Intake, 400,000 miles and counting.
If it isn't under warranty, I'll fix it myself.
  #10 (permalink)
Old 03-05-2012, 09:26 PM
Brown Falcon's Avatar
Brown Falcon Brown Falcon is offline
1995 Ford F-350
Brown Falcon has a great reputation on FTE.Brown Falcon has a great reputation on FTE.Brown Falcon has a great reputation on FTE.Brown Falcon has a great reputation on FTE.Brown Falcon has a great reputation on FTE.Brown Falcon has a great reputation on FTE.
Mine were leaking a few weeks ago and my stock lights were getting cracked and looked terrible. I went ahead and ordered the clear/LED cab lights from LMC. THey're awesome!
See pic in sig!
__________________
Brownie (Evan) Ooh-Rah! Once a Marine Always a Marine Oregon Chapter Member
'95 F350 CC 4x4 - 7.3 PSD, 190k, Built E4OD, SRW Conv, 4x4 Conv, Rosewood Stage I's, PHP Chip, 6637 Intake, 3" DP, Lost Kitty, 4" Exhaust, 3" RSK, 38 gal rear tank, fuel vent mod, 140v IDM, HPX, FPR Shim, 3.55 gears
'10 Escape, 200hp 3.0 V6, 4x4 - Stock
  #11 (permalink)
Old 03-05-2012, 09:37 PM
ReBilld's Avatar
Quote:
See pic in sig!
Those are pretty cool. This truck is a low budget project though. I picked it up cheap with a bad trans and I'm just gonna use it for a work truck. It looks kinda rough. Puttin nice stuff like those lights on it would be like puttin lipstick on a pig !
Maybe on my crw cab project though!
  #12 (permalink)
Old 03-06-2012, 08:26 AM
nateairman's Avatar
I should have the clear ones in a few days! Post a photo lights off....
__________________
  #13 (permalink)
Old 03-06-2012, 08:56 AM
Oldsmoky92 Oldsmoky92 is offline
Oldsmoky92 is starting off with a positive reputation.
Hope you find your leak. I would like cab lights but i dont really wanna go drillin a bunch of holes in my cab.
__________________
96 CCLB, ZF, 4x4, TS 6 pos, 287K and counting.
95 ECLB, swaped in ZF, 4x4, possibly going to be a flatbed dually project.
  #14 (permalink)
Old 03-06-2012, 09:36 AM
tshrager's Avatar
tshrager tshrager is offline
tshrager has a good reputation on FTE.tshrager has a good reputation on FTE.
Don't want to hijack, but I've got some rust around the windshield I'd like to address this spring. How big of a pain in the **** is it to take that windshield trim out without munching it?
  #15 (permalink)
Old 03-06-2012, 10:07 AM
fordpride's Avatar
1997 Ford F-250
I don't think you can get it out with out breaking it
__________________
Tags
cab, ford, lights, mark, sells
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
