Engine Decision to make....
#31
I agree. I've been known to scab together engines myself. Well... you saw the 390 in my '56, right? That thing is in worse shape than your 351W and it runs pretty darn good. If there is no lip at the tip of the bores (not counting the carbon ring) and there is crosshatching still visable, you're in really good. Crank kits are no big deal. The only other high wear item i look at is the cam bearings. And since you're talking honing out yours, you'd probably want to vat it clean. For $75-100, the machine shop should vat the block/hardware and tins and install cam bearings for ya. The only other thing I can think of, machine-wise, would be balancing the rotating assembly. Some suggest to do it, some say its not necessary. As long as you're not changing the pistons, i think you'd be ok. If you are are going to replace the pistons (new-std bore) then it might be wise to balance the rotating assembly. Typical prices for balancing is around $150.
Do you know the milage that is on this engine/tranny by chance?
#32
Once you find a machine shop check with them sometimes they will trade your 351 for a 302.... Doesn't hurt to ask... that is how a friend got a 289 for his Mustang... He took the engine into the shop to have it built (that he bought at a junk yard). He told the shop what he was looking for and they took him into a store room and showed him a 289 that they could trade with him and rebuild for him...
#33
I won't change the pistons unless it would need bored, which I am doubting now since the original x-hatching is visible. The pistons look good except they are a little carboned/oiled up. but not much at all. And I have done the crank kit route before. Thanks Dano!
#34
#35
#36
Another thought too. Alot of times machine shops build up and engine for a customer and they never come back to pay the bill. These engines are usually for sale at only what is owed on the bill. And in some cases the machinist can make changes to these engines to beeter suit they needs of your vehicle. I know my guy has to do this from time to time when he gets a deadbeat customer. Might be something to look into aswell, could get a rebuilt engine cheap...
#37
#38
Jeff,
At Neal Autoparts Salvage yard in Peoria (1-800-548-2138), they have a 302 out of a 1996 Ford Explorer for $500. I like 1996 ford explorer motors because they have the GT40 heads which flow much better than the E7 heads. Further, the motor is stated to have 119,000 miles.
If you choose to go with the 351, that is a great choice too! Just thought I would pass the information along.
Lance
Lance
#39
on
Anybody know what it costs to bore one? Around here in 1995 I paid aprox $20 per cylinder. That's JUST the bore. Unless I come across something else this week, she will go to the machine shop....I guess. At least it's not trashed beyond repair. Just because you can hear them run doesn't mean they are in good shape! I will probably stick with what I got...I already bought a new oil pan to fit the JAG IFS...just gotta get over it and move on!
#40
Jeff,
Lance
Lance
#41
Jeff,
This is off topic for this forum, but my father is in the process of building a 1932 3 Window Coupe. I purchased him a 1996 Explorer engine (100,000 miles) from the Y-yard in Effingham. I am going to take the engine apart to have the block tanked, get a 3 angle valve job, and hone the cylinder. I will then put it back together with new bearing, rings, and cam. I fully expect this engine to make around 300 hp and achieve close to 20 mpgs which will make for a great engine for my father.
Last month, I built a 331 stroker motor for a friend to put in his 1967 Mustang. He's got it back in the car and tearing up the roads already.
Lance
P.S. I found the engine on www.car-part.com
1996
Engine
Ford Explorer
ran good 119,000
A 00019753 $500
Neal Auto Parts USA-IL(Peoria) E-mail 1-800-548-2138
Lance
1996
Engine
Ford Explorer
ran good 119,000
A 00019753 $500
#42
With gas doing the climb again, I am not sure what way to go, but smaller sounds good right now!
Also the 302 EFI is more common and better looking IMHO.
And better support on the web, although the 351W EFI is similar.
I did buy a different oil pan and oil pick up tube for the 351W to fit the JAG IFS...that was $100 bucks.
How much difference in mileage do you guys think there will be?
Sorry, I am still on the top of the fence.
I am not really looking to build a drag truck. Just something that runs nice and does the job.
I keep thinking about how distinct the sound of a 5.0 in a mustang sounds. You can tell it's a Stang without even looking...
Just rambling...thanks guys
#43
I can only speak regarding the engines in trucks, and a mustang, but I have gotten 21 mpg as an average hand calculated mileage in my 1989 f150 with 3.08 gearsa and a 5 speed. That was about 6ish ears ago when I last drove it out to the drilling company I was working for. Back when I was a teenager and drove the truck nice it got even better then that!
The mustang got 23-26 mpg depending if you could keep your foot off of the floor.
The last 351w my dad had was brutal on gas. That was back in the early 90's, but it never got over 15mpg. (he sold that thing and traded for a diesel and never looked back to gas)
#44
I tore apart my $175 salvage yard...'95 351W efi motor.
It is original bore, definitely needs a rebuild. crank needs reground or replaced.
I am trying to decide if I spend a ton of money on it, or find a donor 302 efi.
I wanted a 302 in the beginning and the salvage yard guys said this was a good running motor, so I didn't think and just jumped on it. I don't know about the heads yet, haven't torn into them. Well I did take apart just one valve and the guide,valve, were in good shape.
Trying to decide what to do...
#45
Well Gentleman, I want to thank you for all your input.
I bought the 5.0 that Lance Hogan brought to my attention.
Now I got some stuff to look into.
I am still going to run EFI. But now it's a little less mind boggling to figure out
and it should be a little better on fuel.
This is what I really wanted in the beginning, hope I didn't let anybody down!
You freakin' GEARHEADS !!!!
