Ever seen a 3bbl carb??? - Ford Truck Enthusiasts Forums
Old 03-04-2012, 09:28 AM
1983F1503004x4 1983F1503004x4 is offline
1983F1503004x4 has a very good reputation on FTE.1983F1503004x4 has a very good reputation on FTE.1983F1503004x4 has a very good reputation on FTE.
I didn't know they made them until I was looking at fleabay and saw this:
1983 Ford 7.5L 460 V8 OHV Van Truck w/ auto trans 3 BBL Carburetor 40-807 REMAN | eBay
I thought the 460's came with 4 bbls?
Old 03-04-2012, 09:33 AM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is online now
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
Wow! That does look complex. Have never heard of that carb. Subscribing to this thread just to see what the "big boys" have to say.
Old 03-04-2012, 10:22 AM
ArdWrknTrk ArdWrknTrk is online now
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
That's a governor carb off a U-Haul or other fleet vehicle.
On Edit: It's not like anything I've seen on a 460 van or truck.
I don't know what kind of manifold it would fit.
Last edited by ArdWrknTrk; 03-04-2012 at 11:51 AM. Reason: took a look at other views
Old 03-04-2012, 10:24 AM
Franklin2's Avatar
Franklin2 Franklin2 is online now
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
I see 2 barrels myself. Probably some odd duck California emissions setup.
Old 03-04-2012, 12:59 PM
f100beatertruck's Avatar
f100beatertruck f100beatertruck is offline
f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.
I don't know what the heck that thing is...
But I've seen a 3bbl carb. Back before the Dominator was big Holley, and probably others, played around with 3bbl carbs. They looked similar to 4bbls but the secondaries I believe were cut out and made into one large oval bore with an oval butterfly in them. They were like 900 or 1000 cfm. Dominators just worked better and that was the end of them.
Google Holley 3 barrel carb.
Old 03-04-2012, 01:19 PM
cj06's Avatar
cj06 cj06 is offline
cj06 is gaining momentum as a positive member of FTE.
where's the 3rd barrel ?
and the air cleaner ?
Old 03-04-2012, 02:20 PM
Archion's Avatar
Archion Archion is offline
Archion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputation
Honda Preludes used a 3 bbl carb. The tiny 3rd barrel had something to do with emissions.
Old 03-04-2012, 06:12 PM
The primary is to the left of the big venturi (secondary), you can't see down it though because it looks like the choke plate is completely closed.
What's the purpose of the ultra small venturi? Super-atomized fuel?
I'm going to do some digging and see what I can learn.
Old 03-04-2012, 07:10 PM
cj06's Avatar
what's the chance that that carb could be for a propane engine ?
Old 03-04-2012, 07:38 PM
Quote:
I don't really know. I don't know anything about running a vehicle on propane either.
Do propane carburetors have fuel bowls? Common sense and thought says no. It appears that that carburetor doesn't have fuel bowls, and just has fittings for a vacuum line? Look at the bowl vents at the top of the venturi and where they run. It might be for propane.
I saw in the last picture that the carburetor was re-manufactured by US Carburetor Co. of Rosemead, California. I tried looking up the company and from what I saw, it's closed down.
If it's re-manufactured, who manufactured it?
Typing 40-807 into the search bar doesn't make for much either...
Old 03-04-2012, 07:51 PM
cj06's Avatar
i cant see any fuel bowls either , iave seen some 460 engines run on propane fro generators !
also cant find any info on US carbs
Old 03-04-2012, 09:33 PM
82F100SWB's Avatar
82F100SWB 82F100SWB is offline
82F100SWB has a very good reputation on FTE.82F100SWB has a very good reputation on FTE.82F100SWB has a very good reputation on FTE.
That is not a propane carb, judging by all the electrical and vacuum hookups I'd say it is an Import carb, not something for a 460. Looks like a Honda 3V carb for sure:
Old 03-04-2012, 10:38 PM
Just got reading the online article that that above picture came from.
The Honda 3bbl Carburetor came on 1st generation Preludes that had the 1.8L inline-4.
Carburetor Factory - Keihin 3 BBL Exploded View
Turns out it's called the Keihin 3-bbl.
Something interesting that I saw was that Hitachi actually made carburetors. Hitachi are known in this day and age for their electronics like hard disks.
Now I need to see if i can find out what the tiny venturi is for.
Old 03-04-2012, 10:43 PM
cj06's Avatar
WELL , IT IS A HONDA'S , LONG WAY FROM A 460 !
kedwinh's Avatar
kedwinh kedwinh is offline
kedwinh is gaining momentum as a positive member of FTE.
I know they used to make 3 barrel carbs back in the late 60's, think it was AFB. But those were monsters, 2 good size primaries and 1 LARGE secondary. That's the only 3 barrel I've ever heard of but then again I don't mess with foreign cars much.
Bellhousing help ID LilToe 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 07-04-2016 10:15 AM
Carb for 78/79 F150 with 351M sailfast3r 1973 - 1979 F-100 & Larger F-Series Trucks 9 08-15-2015 08:39 PM
83 CA emissions Bronco questions... yamahabiker94 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 04-01-2014 10:10 PM
My new to me 1983 F250 CHADAHAR 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 05-25-2013 02:47 PM
Engine Weight Info 4tl8ford 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 11-15-2008 09:00 PM
Tags
3bbl, 4x4, 86, bore, carb, carbureted, carburetor, diagram, f250, holley, standard, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
