Will these exhaust manifolds work on my '65 F250 / 352? - Ford Truck Enthusiasts Forums
Old 03-03-2012, 08:39 PM
BigMikeUGA BigMikeUGA is offline
BigMikeUGA is starting off with a positive reputation.
Just for clarification, I'm not asking if these are the original stock manifolds for a '65 352, but will they work. I'm thinking of taking the headers off and putting the manifolds back on to quiet it down some.
Old 03-03-2012, 09:52 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.
They sure look like the original "log", type manifolds I took off my '66!
Old 03-03-2012, 09:53 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
^ Not from any F100/350 FE. Enlarge the pic, look at the ID prefixes: One is C8AE, t'other is C3SE, these are car manifolds.
Quote:
Both are from Passenger Cars, the exhaust collectors are in different locations than F100/350 FE exhaust manifolds.
The left (drivers) side 1961/63 T-B (C3SE) manifold may not clear the trucks steering box.
F100/350 352/360/390: The right (passenger) side exhaust manifold is the same 1965/76, could have an ID number of C5TE-9430, C8TE=9430 or D0TE-9430.
D0TZ-9430-A (replaced C5TZ-9430-A & C8TZ-9430-A) .. Right (Passenger) Side Exhaust Manifold / Obsolete
The left (drivers) side exhaust manifold is the same: 1965/67 F100/350 352 & 1973/74 F100 360. ID number C5TE-9431.
C5TZ-9431-A .. Left (Drivers) Side Exhaust Manifold / Obsolete / These trucks have a heat riser valve, the manifold is machined for it.
Excepting the heat riser, 1968/76 left manifold is the same, ID number C8TE-9431 / Ford part number: C8TZ-9431-A
Old 03-03-2012, 10:21 PM
66f-100's Avatar
66f-100 66f-100 is offline
66f-100 is starting off with a positive reputation.
I saw a new pair online for $75 + free shipping. Probably made in China, but if they work, it's a good price. I paid that for a used set.
Ford F350 Truck Ford Pickup 352 390 Exhaust Manifold Pair - AM Autoparts
Old 03-03-2012, 10:36 PM
DrCharles DrCharles is offline
DrCharles is starting off with a positive reputation.
Hm... wonder if those would fit your truck, and my '65 F-350 (which currently has a 360, and someday I'll build the 390 from the pile of parts in my barn). The "AM Autoparts" site only says '68-'76...
Old 03-05-2012, 01:04 AM
Buzz44's Avatar
Buzz44 Buzz44 is offline
Buzz44 has a good reputation on FTE.Buzz44 has a good reputation on FTE.
I thought you were looking to do things to your truck to get better milage. Putting those back on certainly will not help with that. More airflow in and more airflow out= more hp and torque= better mpg. Oh and automatic trans will rob hp and mpg. Just saying.
Check this out
Dean M's 427 on the dyno
Old 03-05-2012, 09:44 PM
CropDusterMan's Avatar
CropDusterMan CropDusterMan is offline
CropDusterMan is gaining momentum as a positive member of FTE.CropDusterMan is gaining momentum as a positive member of FTE.
Remove your headers to go back to manifolds?? If Steve McQueen were here,
he would slap you.
If you want to quiet the truck down, go to a set of 60 Series FlowMasters, but don't go
and do something that's going to choke off the engine airflow. There is so much technology
in mufflers now that still allow decent performance.
If you do this you will no longer be able to refer to yourself as "BigMike". We will call you
"Francis".
Jason
Old 03-05-2012, 10:53 PM
66f-100's Avatar
My truck had headers on it when I bought it. They fit poorly and i was replacing gaskets on a regular basis. I also didn't like removing the header to replace the starter. I replaced them with stock manifolds and haven't had a problem since. Steve McQueen might want to slap me, but it's a truck not a race car. When I want to go fast, I drive one of my Mustangs.
Old 03-05-2012, 11:47 PM
William William is offline
William is gaining momentum as a positive member of FTE.
Manifolds
Truck manifolds are bigger than car manifolds. FE engines (truck) from 65 through when Ford stopped making them use the same manifolds. Likley Ford sells them. Truck manifolds flow pretty well for just driving around. Headders are great for race cars but are a real PITA when it comes to leaks and cooked starters. So if you are just driving your truck, manifolds are fine. Be sure they are flat and true (machine shop) and add a set of gaskets. Follow torque sequence and specifications. True duals with a crossover pipe or even a X pipe if you want to spend a few bucks. Not interested in re-starting the age old pi$$ing contest about headders verses manifolds. This is my opinion based on 50 years experience working on these old trucks. IMHO!
Old 03-06-2012, 12:49 AM
Quote:
FE engines (truck) from 65 through 1976 use the same manifolds.
There is one right side, 2 different left sides.
Likely Ford sells them.
FE truck exhaust manifolds have been obsolete for at least 20 years. See sources below for NOS
DOTZ-9430-A (replaced C5TZ-9430-A) .. Right Exhaust Manifold / Obsolete
Applications: 1965/67 F100/350 352 / 1968/76 F100/350 360/390.
HAVEN FORD in Haven KS has 1 = 620-465-2252.
COLLECTORS AUTO SUPPLY in Oroville WA has 1 = 800-414-4462.
WESLET OBSOLETE PARTS in Liberty KY has 1 = 696-787-5293.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 3 = 800-476-9653.
C5TZ-9431-A .. Left Exhaust Manifold-Use with Heat Riser Valve / Obsolete
Applications: 1965/67 F100/350 352 / 1973/74 F100 360.
KOEHN MOTORS in Wellington KS has 1 = 620-326-5915.
C8TZ-9431-B .. Left Exhaust Manifold / Obsolete
Applications: 1968/72 F100/350 360/390 / 1973/74: F100 390 & F250/350 360/390 / 1975/76 F100/350 360/390.
CROSSET FORD-LINCOLN in Crosset AR has 1 = 870-364-2162.
GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
CARPENTER NOS OBSOLETE PARTS has 23.
C5TZ-9A427-A .. Heat Riser Valve-1.00" thick body / Obsolete / 39 available NOS
Applications: 1965 F100/350 352 before serial number 672,001.
D3TZ-9A427-A (replaced C5TZ-9A427-D 1/1973) .. Heat Riser Valve-1.56" thick body / Obsolete / 21 available NOS
Applications: 1965 F100/350 352 from serial number 672,001 / 1966/67 F100/350 352 / 1973/74 F100 360.
Exhaust Manifolds ? sonny1965 1961 - 1966 F-100 & Larger F-Series Trucks 6 04-16-2015 04:04 PM
WTB: Air Cleaner Assbly - 65' F100 352 HochF100 WTB - Parts & other 3 12-24-2014 09:53 PM
Help!! 65 F100 352 Throttle Cable to Carb bracket? PharmerChris 1961 - 1966 F-100 & Larger F-Series Trucks 12 11-02-2014 01:45 PM
'65 Galaxie with a 352 fearfactory FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 19 12-29-2006 04:02 PM
352 engine problem amterrell 1961 - 1966 F-100 & Larger F-Series Trucks 12 12-26-2006 10:01 PM
Tags
1967, 1973, 352, 65, 9430, d0te, drivers, exhaust, f250, ford, manifold, manifolds, side, specs, torque, truck, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
