'79 F250 351M carb replacement
You're definitely going to need one of these jet kits.
Might need a secondaries spring kit Holley 20-13 Holley Vacuum Secondary Components
Probably a set of accelerator pump cams, too Holley 20-12 Holley Accelerator Pump Cam Assortment
Ok,,, 77 F150 4x4 4 speed, 351M I went with the Edlebrock 400 4bbl intake, holley 600cfm manual choke carb, I am at 3600' elevation, other than a slight tune with a vac. gauge, it was all bolt on, no pressure reg. no new jets, nothing, runs great! Whole new truck, actually has the fuel and air it needs to run good. My suggestion, go to Summit Racing, order 4bbl intake and 4bbl carb of your choosing, bolt it on and drive, you will be happy. Only thing it magnified was the fact I need to re-gear to 4.10's!
Don't make it hard, carbs and intakes are NOT voodoo science.
I would hold off putting a 4bbl carb on a 2bbl intake,,,, did it, hated it, doesn't flow like it should, I went back to my 2bbl and found 4bbl intake on CL and waited for funds to buy carb. IMO, save your cash and go 4bbl intake and carb.
And vacuum gauge goes on manifold vacuum when tuning.
Ok i will do that. My reason for getn another carb is my motorcraft 2bbl is pouring fuel into intake i can smell it in my oil and i tried lowering my float and put brand new power valve but it still doing it. Do u hav any suggestions for me. I dnt wana ruin my engine its very solid for how old it is. I thank u for ur help pickupman2
As posted earlier, go here~~> Carburetor Lookup
buy a reman, install and save $$ for 4bbl ugrade.
#29
