Interior lights on and won't go off - Ford Truck Enthusiasts Forums
Modular V10 (6.8l) SPONSORED BY:
Old 03-03-2012, 04:01 PM
hoss1981 hoss1981 is offline
hoss1981 is starting off with a positive reputation.
I have 2000 Excursion that the interior lights won't go out. It acts like a door is not shut tight. Guy at Auto Zone recommended W-D 40 in the latches and work the latch a few times. Didn't work. Any other suggestions?
Old 03-03-2012, 07:37 PM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
If you move the dimmer wheel up until it clicks the interior lights will stay on the whole time. If thats not the issue in my experience its usually a bad sensor in the latch that senses when the latch is closed OR there is broken wires between the door and pillar.(at front of door above top hinge) Had this problem the other year on the Explorer and it was broken wires.
Old 03-03-2012, 07:55 PM
jh818's Avatar
jh818 jh818 is online now
jh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputation
Don't forget the latch in the back hatch, too. There's a switch there as well.
Old 03-03-2012, 08:55 PM
rvpuller's Avatar
rvpuller rvpuller is offline
rvpuller is a splendid one to beholdrvpuller is a splendid one to beholdrvpuller is a splendid one to beholdrvpuller is a splendid one to beholdrvpuller is a splendid one to beholdrvpuller is a splendid one to beholdrvpuller is a splendid one to beholdrvpuller is a splendid one to behold
When you use the WD-40 in the latches you have to use a lot of it to get any dirt out of the small ball detentes, I mean until it's running out the bottom of the door.
Denny
Old 04-25-2012, 06:48 PM
fballxl5 fballxl5 is offline
fballxl5 is starting off with a positive reputation.
F150 Interior Lights Won't Go Out
Iíve had a running battle with 1999 F150 XLT dome and cargo lights failing to shut off when the door is closed. There is also the instrument panel warning light indicating that the door is not closed. I had the driver side door switch professionally replaced, but this only helped for a short while. The problem returned on hot (~90F) days. I complained to the mechanic but he did not know what else to do. I then took the door and latch apart to figure it out. My take was that the mechanic used too much grease on the connector. It was cleaned and put back together with some improvement, but the problem eventually returned with hot weather. I can hear the click of some component deep in the dash after the door closes and when the dome and warning lights finally turn off. Interim repairs have been swapping the relays in the interior fuse-relay panel, disconnecting the battery, and removing the interior lamp relay (Relay 1) during the hot weather (best method). The generic wiring diagrams Iíve looked at so far indicate that the component feeding power to the interior lamp relay is the generic electronics module. That may be replaced next if it can be accessed without removing the whole dashboard. I was clued in to heat sensitive Ford relays when the starter motor seemed to fail on a very hot day. The starter motor was professionally replaced, but the problem returned as soon as it got hot outside. I replaced the started solenoid and the problem disappeared. Good luckÖI will add to this thread once I get it figured out.
Old 04-26-2012, 10:09 AM
Problem solved. I found a broken wire in the rubber sleeve between the door post and the door. Butt spliced it and now it works fine. Thanks to anyone who made suggestions.
'08 f250 tailgate won't latch RancherJV 1999 to 2016 Super Duty 2 09-25-2016 08:32 PM
Interior door handle - catching hillcountryflt 1967 - 1972 F-100 & Larger F-Series Trucks 3 11-30-2014 01:33 PM
Tailgate Latch Handle KsCop 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 20 09-11-2014 11:13 PM
Seatbelt won't latch shut bigtexan99 1999 - 2003 7.3L Power Stroke Diesel 5 01-09-2014 07:11 PM
Hood won't latch 2000 xlt woodworx Expedition & Navigator 5 12-02-2007 06:15 PM
Tags
dome, f150, f450, flex, ford, interior, light, lights, navigator, shut, truck, trucks, turn, uot, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Fordģ is a registered trademark of the Ford Motor Company.
