Air filter options - Ford Truck Enthusiasts Forums
Air filter options
Old 03-03-2012, 10:10 AM
jazz1's Avatar
jazz1 jazz1 is offline
jazz1 is starting off with a positive reputation.
Air filter options
I am thinking eliminating stock air cleaner on my '86 300 6 and putting something like this on to increase air flow. What are you using? Eliminate the stock "can" completely
EXTREME AIR CLEANER ASSEMBLY 14X3 INCH BLACK B-3 | eBay
Old 03-03-2012, 10:41 AM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
I am using the stock "can" as it works best, at least in winter.
I see no reason to replace it and any performance improvements would be imaginary, but you're free to give your money to whomever you like.
Old 03-03-2012, 11:41 AM
82f100460's Avatar
82f100460 82f100460 is offline
82f100460 is gaining momentum as a positive member of FTE.82f100460 is gaining momentum as a positive member of FTE.
I would keep it stock. Goint to a different air cleaner will not likely increase air flow...it is not the limiting component in the fuel/air system.
Airflow is going to be controlled by your carb and is function of engine displacement, cam, valves, intake and other variables. You can likely not run a filter at all and not increase air flow.
In High performance applications, where the above variables have been modified, the air filter and house may become limiting and and upgrade is warranted. But I aslo would not sacrifice drivability and/or starting ease (especially when its cold) for something that "looks" like it would increase performance.
Old 03-03-2012, 12:55 PM
f100beatertruck's Avatar
f100beatertruck f100beatertruck is offline
f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.
I plan on using a dual snorkel air cleaner from a 5.0 mustang on my 393 stoker that I'm building if that tells you anything. I'm going to duct the snorkels to a cold air source and hook up the heat stoves for faster warm up in the winter.
My problem with filters like that and any open filter is that it's sitting right over the hot engine. Cold air is more dense and can make more power.
Old 03-03-2012, 10:48 PM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is offline
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
Why plumb both snorkels to hot air? Are you planning on racing before the engine warms up?
My plan, when I get to it, is to block the hot-air opening on the driver's side snorkel and run two temp sensors to control the flappers individually. That way the one on the driver's side will stay closed in cold weather and yet will open fully in hot weather. And, there will be just a little bit less hot air to taint the cold air on that snorkel.
Hijack over.
Forgot to say you should read this thread: Stock Air Cleaner The reasons discussed there are still very valid. No need to rehash.
Old 03-03-2012, 11:47 PM
Quote:
Yeah, the cold start drags... Didn't you hear of them?
I'm undecided but my OCD may kick in and force me to have symmetry since they're both there.
Old 03-04-2012, 08:39 AM
whisler whisler is offline
whisler is gaining momentum as a positive member of FTE.
Not to hi-jack the thread but will the dual snorkel air cleaner from a 5.0 Mustang fit on a Motorcraft 2150 carb.
I have a line on one but don't want to buy without knowing it will fit. It is an internet sale so I can't just go measure it.
Old 03-05-2012, 08:26 AM
Gary: why couldn't you just tee off the one temp sensor rather than using two. If the hot air inlet is blocked, then the flapper being open over it when cold wouldn't matter, Right?
Old 03-05-2012, 09:09 AM
Gary Lewis's Avatar
Quote:
Actually, that might work nicely. As long as you have the sensor behind the snorkel that has hot air then I think it would work. The only issue would be as the air gets hot and the flapper starts to open to allow cold air in, as the sensor is only sensing the air in the one snorkel. The air in the other snorkel will be COLD, so the overall air temp going into the carb would be colder than the sensor realized. But, that might not be a problem.
I guess I could try and add the 2nd sensor if it doesn't work as expected. But, as easily as the air cleaner comes off it wouldn't matter when I put the sensor on. So, I might as well try one and go to two if needed.
Good idea!
Old 03-05-2012, 01:43 PM
The way the illustration in my manual looks, if you had the drivers side snorkel warm air inlet capped, and the vacuum motor was operating off of the temp. sensor, then when cold, you would get little or no air from that snorkel, warm or cold.
With only drawing air through the passenger side snorkel, it should act like a single snorkel until warmed up then switch to dual cold air inlet.
Am I visualizing this right?
Old 03-05-2012, 01:51 PM
Gary Lewis's Avatar
Yes, you have it right. It would work fine when full hot s needed and when full cold is needed.
My concern, and it is probably a minor one, is in the transition phase between full hot and cold. Since there is only one sensor, and since it is in the air stream from the passenger's side snorkel, it will only be controlling the temp at the outlet of that snorkel. None of the air from the other snorkel can get to the sensor. But, at the same opening there will be full cold air coming in from the driver's since since you either have no air or cold air.
Old 03-05-2012, 02:09 PM
Your temp. sensor must be in a different position than mine, as mine is in the top of the air cleaner, over the main body of the air cleaner and across from the snorkel. In that position, I don't think it would make much difference even in the transition.
Old 03-05-2012, 02:18 PM
Gary Lewis's Avatar
Duh! Why didn't I realize that? Well, maybe because the air cleaner on Dad's truck hasn't had the flapper hose hooked up in almost forever. And because it was broken in about a dozen places I swapped it out with another one I'd picked up along the way - one which has 3 sensors on it. I don't know which truck it came from, but I know it was from another 80's era truck.
Anyway, it has two sensors just behind the snorkel, which is on the driver's side, and one in the lid inside the land for the filter. So, if that one were used it could be positioned to the rear where it would be roughly the same distance from both snorkels and it would basically be sensing the air going into the carb - regardless of from whence it came.
Good idea!
Old 03-05-2012, 04:44 PM
I think that one of the devices in the snorkel is the vacuum motor that opens and closes the flapper and the other is called a Cold Weather Modulator (CWM). My manual says that it keeps the flapper from trying to close during periods of low vacuum, like acceleration, by acting as a vacuum trap. Once it senses a high enough temp. it allows vacuum to vent.
My air cleaner doesn't have the CWM. Also the vacuum motor is defective and I'm trying to find out where to get another. I'd rather buy a new one than trust a 30- year old one from the JY, but I may not have a choice.
Old 03-05-2012, 05:49 PM
Bi-Metalic valve. That's what controls the air cleaner diverter valve aka "the flapper valve". When cold it allows vacuum flow to suck the diverter valve closed. Once warm it cuts off flow. It's a little silver disk inside the air cleaner housing.
It's also called a "Sensor Assy. (Carburetor air cleaner temperature control)" in the parts manual...
@Gary, some are located in the bottom housing, some in the top, etc. Depends on the engine.
Shackle Leveling Kit Install How-to?? jkidd_39 1999 - 2003 7.3L Power Stroke Diesel 24 03-31-2014 06:45 PM
headliner Vinford 1973 - 1979 F-100 & Larger F-Series Trucks 4 03-22-2013 09:31 PM
Found a sweet hood! Plain Jane 1987 - 1996 F150 & Larger F-Series Trucks 31 05-22-2012 07:49 AM
Q logic subwoofer box. DieselBeast01 2004 - 2008 F150 12 11-04-2011 12:16 AM
aFe air fitler stock airbox chairman13 6.4L Power Stroke Diesel 4 01-07-2010 04:14 PM
Tags
1985, 2012, 3514v, 351w, 50, 58, 80s, adobe, air, cleaner, duct, engine, f150, f250, ford, ho, motor, options, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
