Air filter options - Page 4 - Ford Truck Enthusiasts Forums
Air filter options
  #46
Old 02-23-2014, 06:35 PM
DentyBlueAZ's Avatar
DentyBlueAZ DentyBlueAZ is offline
DentyBlueAZ is starting off with a positive reputation.
Hey gary thanks for the advice, i can't find how to start my own thread? do i need 10 posts? Well my amigo and I did more work today, taped up loose wiring with the stereo, and labelled the jungle underneath the instrument panel. But here's a picture of the air cleaner assembly
i need an intake tube with the vacuum motor. and is there supposed to be a hose coming off the top of of the PCV valve?
  #47
Old 02-23-2014, 09:16 PM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is online now
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
On the main page of this forum, here, there's a button in the lower left called New Thread that takes you here. Don't know about needing a number of posts before you have a new thread, but that is possible.
However, I can't see the picture. You have to have your pictures hosted somewhere on the internet, not on your PC, to post them. I use FTE and you can get there by clicking on User CP in the upper left and going to Pictures and Albums. Start an album and add some pics from your PC. Then scroll down and copy the BB code on that pic and paste it into a post.
There is supposed to be a hose coming off of the PCV valve and it goes to a large port on the bottom of the carb or intake manifold.
  #48
Old 02-23-2014, 10:18 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Yes, on the front page is
No post number requirement to start one.
We can't see his picture because he's trying to source it from his AOL e-mail which we can't get into....
  #49
Old 02-23-2014, 11:23 PM
haaaaaaa haaa everyone needs an AOL email account for spam and other stuff its a lifesaver!!! And how else would I find out how much Kim Kardashian weighs!!!!
  #50
Old 02-23-2014, 11:30 PM
alright so on top of the PCV valce is a nipple thing above the larger hose, just to double check no hose goes from the top of the PCV valve to anything? The big hose to the carburetor is all good, I have that. And also, I have to get more specific the numbers, but I have a Carter AFB competition series carburetor, i read throughout the forum here and noticed you're a fan Mr. Lewis? So it's a good carburetor?
  #51
Old 02-24-2014, 07:57 AM
Gary Lewis's Avatar
Most of the PCV valves have an extra nipple molded into them, but they aren't open - there's no hole. So there's no hose to be connected.
As for the carb, yes I am a fan of Carter carbs. The AFB is essentially what the Edelbrock Performer series is, which includes the 1406 that I'm running. They a good, solid carbs and are pretty much set-and-forget as there aren't that many things to go wrong. They aren't terribly sophisticated but that simplicity is a blessing when you want to drive the vehicle instead of tinker (repair).
  #52
Old 02-24-2014, 09:38 AM
tree medics's Avatar
tree medics tree medics is offline
tree medics is starting off with a positive reputation.
If you get a pcv valve with the extra nipple open , they usually have a plug. You twist it off and push it in the upper nipple.
Shackle Leveling Kit Install How-to?? jkidd_39 1999 - 2003 7.3L Power Stroke Diesel 24 03-31-2014 05:45 PM
Cast vs. Forged Cranks jseim44 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 6 03-23-2012 07:51 PM
Considering switching back to points 73FordF100 1973 - 1979 F-100 & Larger F-Series Trucks 15 01-25-2012 01:44 PM
So, I need an intercooler. Jeepincj7 1994.5 - 1997 7.3L Power Stroke Diesel 20 01-02-2012 02:54 PM
Q logic subwoofer box. DieselBeast01 2004 - 2008 F150 12 11-03-2011 11:16 PM
Tags
1985, 2012, 3514v, 351w, 50, 58, 80s, adobe, air, cleaner, duct, engine, f150, f250, ford, ho, motor, options, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
