Air filter options - Page 3 - Ford Truck Enthusiasts Forums
Air filter options
  #31
Old 03-06-2012, 06:27 PM
f100beatertruck's Avatar
f100beatertruck f100beatertruck is offline
f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.
Quote:
Originally Posted by whisler View Post
So that means my 2bbl. 351 should take the "A" or yellow stripe, right?
Yes. Not knowing what engine you had 5.8 2bbl or 4bbl, I scanned though the calibrations and all of the 2bbl cals used the "A" and all the 4bbl's used the "C".
  #32
Old 03-06-2012, 11:39 PM
whisler whisler is offline
whisler is gaining momentum as a positive member of FTE.
One more simple question, if I may. It appears that to remove this part you have to drill out a rivet and then re-rivet the new part in . Is this correct?
  #33
Old 03-06-2012, 11:51 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
I used a sheet metal screw.
  #34
Old 03-06-2012, 11:53 PM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is online now
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
Yes, you do have to drill the rivet out. But I prefer to use a screw and a nut to replace the rivet so I can take it apart again. You could use a sheetmetal screw as well, but I like to use lock washers or locktite and they work better with screws and nuts.
  #35
Old 03-06-2012, 11:58 PM
Boy, Gary, if you can get a nut inside that tube, you must have little bitty hands.
  #36
Old 03-07-2012, 08:58 AM
Gary Lewis's Avatar
Nope, rather large really. IIRC, I used a piece of tape to hold a nut inside, and put it there through the hole for the actuator. But, as I now think about it, with Loctite on the threads there is little, if any, chance I can get the nut off later since that tape isn't going to keep it from turning.
Looks like a sheetmetal screw is the best approach. Chris wins.
  #37
Old 02-20-2014, 11:11 PM
DentyBlueAZ's Avatar
DentyBlueAZ DentyBlueAZ is offline
DentyBlueAZ is starting off with a positive reputation.
I live in southern AZ and it gets pretty dusty down here. The 83 I bought didn't have any air intake tubing just a hole in the base, I am going to hit a junkyard and take a gander through there, but I was hoping someone could enlighten me as to what is the function of the cap on the intake tube and the hose that goes back into the air cleaner? thanks, sorry, I'm a rook.
  #38
Old 02-20-2014, 11:26 PM
ctubutis's Avatar
Quote:
Welcome to FTE.
Do you think you could post a picture? I'm not sure what you're asking about..
  #39
Old 02-20-2014, 11:27 PM
Gary Lewis's Avatar
I don't understand what you mean by "the cap on the intake tube and the hose that goes back into the air cleaner". But I will try to explain what the air cleaner pieces do:
  • Thermostat: There's a thermostat inside the air cleaner that is connected to manifold vacuum and supplies vacuum to the vacuum motor. It regulates inlet air to the carb - if the air gets too cold it closes the flapper to pull air from the exhaust, and if too hot it opens the flapper to get air from the radiator support.
  • Snorkel: Connects the air cleaner with the two hoses and provides a spot for the vacuum motor and flapper.
  • Vacuum motor: Round thing, probably the "cap" you mentioned, that pulls the flapper shut or opens it as controlled by the thermostat.
  • Hose to radiator support - gets fresh/cold air
  • Hose to exhaust manifold - gets hot air
That is a very well engineered system and people who ditch it are not well educated in how it works and why it is needed.
  #40
Old 02-20-2014, 11:41 PM
Thanks Ctub and Gary! yes gary, the snorkel! i knew i wasn't crazy, and thanks for the explanations. Ctub i will post pictures this weekend gotta head into work and bartend. woooo i knew that little gas cap looking thing was important, so when i get this taken care of, and throw a new air filter in how much do you think that will reduce my Hydcarbon and CO emissions? the standards in AZ are 300 ppm for HC at idle and i was at 1582 and CO % is 4 and i was at 7.64...... thanks again guys!!!
  #41
Old 02-20-2014, 11:48 PM
ctubutis's Avatar
Quote:
I don't know, either, kinda sounds like he's trying to describe the pcv valve in an oil filler cap or maybe the vacuum motor on the snout and the vacuum tube to manifold vacuum... hard to know....
  #42
Old 02-21-2014, 12:03 AM
haa haa thanks guys, i was searching for pictures to vacuum motor and the picture i clicked took me to a thread back here on this site. and yes it is the vacuum motor. Disconnected hoses and plugs, where do they go? hate to be the FNG. but somebody's gotta do it.
  #43
Old 02-21-2014, 12:04 AM
Gary Lewis's Avatar
Chris - I think vacuum motor and its hose.
Denty - This isn't going to help very much. I say that for two reasons. First, it just maintains a constant air temp going into the carb, which is necessary in order to control the air/fuel ratio closely. But, your temp at present surely isn't way off the set point for the thermostat, so there will be little change.
Second, if the previous owner was so intelligent that he took all that off he probably did other things to the emissions system that are waiting to bite you.
  #44
Old 02-21-2014, 12:29 AM
Thanks for the warning Gary. I cant wait to post pics, learn from you guys, and get a laundry list of sh*& i gotta do to my baby. my goal is have her ready for hunting season.
  #45
Old 02-21-2014, 07:44 AM
Gary Lewis's Avatar
You should start your own thread. By using this one you only get the few people subscribed to it. But starting a new thread will get much more attention and lots more help.
Nice 67 on Ebay Uni Moe 1967 - 1972 F-100 & Larger F-Series Trucks 11 11-25-2015 12:20 AM
Wheel / Tire spring sanity check before I buy please... Travis O'Connor Excursion - King of SUVs 7 10-22-2015 09:49 PM
Shackle Leveling Kit Install How-to?? jkidd_39 1999 - 2003 7.3L Power Stroke Diesel 24 03-31-2014 06:45 PM
headliner Vinford 1973 - 1979 F-100 & Larger F-Series Trucks 4 03-22-2013 09:31 PM
1995 Nascar Craftsman Truck TexasGuy001 1987 - 1996 F150 & Larger F-Series Trucks 7 05-17-2012 12:40 PM
Tags
1985, 2012, 3514v, 351w, 50, 58, 80s, adobe, air, cleaner, duct, engine, f150, f250, ford, ho, motor, options, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
