AE (AutoEnginuity) Beginner-Advanced! - Page 7 - Ford Truck Enthusiasts Forums
  #91
Old 06-03-2012, 11:02 PM
Tugly's Avatar
Tugly Tugly is offline
I'm a cautionary tale.
Tugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputation
Quote:
Originally Posted by bigb56 View Post
Cleared them today then ran the KOER and the PO475 showed up. Do you clear KOER codes as well or do they automatically reset each time you initiate the test? The PO475 only shows up on KOER
Hmmm... EBP, MAP, and BARO should read about 13 PSI or a little lower in AZ (KOEO), but they should read real close to each other. 4 PSI difference is way off and that would likely throw a code. The device with the reading farthest from 13 PSI (or the other two readings) loses.
  #92
Old 06-03-2012, 11:16 PM
bigb56's Avatar
bigb56 bigb56 is offline
bigb56 has a great reputation on FTE.bigb56 has a great reputation on FTE.bigb56 has a great reputation on FTE.bigb56 has a great reputation on FTE.bigb56 has a great reputation on FTE.bigb56 has a great reputation on FTE.
Quote:
Yes Map and Baro are both at 13.2 (I'm at 2200 ft) and EBP is over 17.
  #93
Old 06-04-2012, 07:31 AM
Tugly's Avatar
Do you ever watch Mythbusters? This is where Adam would say "Well there's your problem." You already know you need to check out that EBP sensor. Congratulations... you're already troubleshooting with AE!
  #94
Old 06-09-2012, 09:09 PM
bigb56's Avatar
Today I removed the tube and the sensor and cleaned them again. The tube had a bit of soot, not much. This time I dug into the sensor more than last time, and sprayed some PB blaster in it. I got a lot of soot out of it. Put it back together and the EBPS dropped to 15 (KOEO), 2 PSI less than before, but still 2 PSI over baro & map. Still throws the code on KOER. I'll try cleaning the sensor one more time before ordering a new one.
I am getting a couple of codes on the hybrid instrument cluster that keep coming back, one is a communication bus fault and the other is missing or invalid rpm data. The tach seems to be working fine on the dash and in AE.
I did have my VSM replaced due to inopoerative power door locks, accessory delay, autolamp, door ajar switch, courtesy lamps and probably a couple things I forgot. Resetting the old VSM would fix the problems temporarily, but the new VSM seems to have fixed everything for good.
I was getting the instrument cluster codes before all this anyway. I do know on my 02 the VSM and the cluster work together on some of that stuff.
  #95
Old 12-16-2012, 10:34 AM
double ott ex's Avatar
double ott ex double ott ex is offline
double ott ex has a good reputation on FTE.double ott ex has a good reputation on FTE.double ott ex has a good reputation on FTE.
I know this is an old thread, but I found it to be good reading and am thankful you started it Tugly. keep up the good work and happy hollidaze
DOE
  #96
Old 12-16-2012, 11:16 AM
Shake-N-Bake's Avatar
Shake-N-Bake Shake-N-Bake is offline
Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.
While I'm on the topic of this screen...
You can only make adjustments to the settings while the unit is hooked up to the vehicle and the key is on. For better charting and visual feedback on the bar graphs, set the limits per parameter to realistic values. The default RPM is 8000. On a diesel? Really? I try to keep my charts as simple as possible, so I plan my ranges.
Multiples of 0-1 and 0-3.5 have been working well for me so far. What do I mean by that? One parameter might have a scale of 0-10, another 0-100 (like MPH and % Duty Cycle). 0-350 is great for TFT and EOT, 0-3500 is good for RPM and ICP. I'm building a pattern where my scale on the right is a 0-100 and the left is a 0-3500 to keep the information close to the center of the chart.
Fantastic idea! Genious really....
Thanks for the tip.
  #97
Old 12-16-2012, 12:29 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
I frequently use Open Office and one part tripped me up at first. Here is the solution for what I ran into.
[/quote]
This worked because files with the extension .csv contain comma separated values.
Also if you change the Character Set to UNICODE - UTF-8 and click OK it will create a spread sheet.
You probably new this but not all do.
Example of tweeked spread sheet. You can see the time delay between parameter samples.
  #98
Old 12-16-2012, 10:52 PM
Tugly's Avatar
Genious? Oh... then I must have ripped the idea off from somebody.
I have a number of saved profiles for making my connections. There is a window that says "New" when I first connect to the truck and I select one of my pre-saved profiles. I have one profile labeled "ICP-IPR" that has all the settings the way I like, with the mins and maxes preset. By having this profile set with the same parameters each time (and in the same order), it makes graphing in a spreadsheet much easier because I just need to cut and paste from a previous saved spreadsheet each time. There are other benefits, which I will list when I have a moment to set up the graphics.
  #99
Old 11-20-2013, 05:55 PM
xbox73 xbox73 is offline
xbox73 is gaining momentum as a positive member of FTE.
  • The security dongle is not a USB storage device per se, it is hardware like a mouse or keyboard. The security dongle can be bypassed to talk to the OBDII interface, but you (and I) don't want a piece of that. It cannot be bypassed in any usable way for the software to function, so it's not worth the effort to look into it. These guys did their homework.
New version 12 (and maybe 11.2? <-- don't know) AE ProLine hardware has anti-piracy features integrated into the ProLine hardware itself, thereby obviating the need for a separate USB security dongle (in addition to the USB cable used to attach the ProLine hardware to the PC), so only 1 USB port now needed for the ProLine hardware, and no risk of losing the USB security dongle.
  #100
Old 11-20-2013, 08:46 PM
Tugly's Avatar
Very cool. Thanks for that update!
  #101
Old 11-21-2013, 01:14 PM
Lambert01's Avatar
Lambert01 Lambert01 is offline
Lambert01 is gaining momentum as a positive member of FTE.Lambert01 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by honeydew View Post
Thought I'd post this here to make those looking at purchasing a computer for AE aware of this type of option.
For AE (and vag-com) I use an Asus EEE slate which runs windows 7 and has two usb ports. A big reason for purchasing this type of unit was to run the vehicle diagnostic programs.
I've found it easier to handle in the vehicle than a laptop and it's nice not having to hunt for the pointer and use a touchpad mouse. Everything can be done with the stylus or finger.
No CD drive so I just copied the disk to a thumb drive and installed the software via that.
Tugly I thought this might be an appropriate hardware experience but let me know if you want this out of your thread and I'll delete the post.
Honeydew,
how has your Asus worked out for you? my only pc laptop just took a dump and now my choice is to go your route(hoping to find one really cheap) or install windows on my macbook and use it there.
thoughts or other ideas that won't cost much.
  #102
Old 11-22-2013, 01:33 AM
SaintITC SaintITC is offline
SaintITC has a good reputation on FTE.SaintITC has a good reputation on FTE.
In many of the threads here people mention measuring "perdels". What is that test / parameter?
And in your configuration screenshot you show that the connection is OBD-II, the AE instructions say to select non OBD-II? I have the newer non-dongle ProLine, with version 11. Is the non OBD-II selection correct?
Thanks, Tom
  #103
Old 11-22-2013, 07:11 AM
Tugly's Avatar
This thread ended up being a rough draft of the AE stuff. Things got more precise here [LINK] and here [LINK].
Everything you're asking (plus a lot more) is covered in those monster threads.
I'm pulling the trigger... need input! Tugly 1999 - 2003 7.3L Power Stroke Diesel 29 09-16-2012 03:30 PM
Only I can make such a mess... help! Tugly 1999 - 2003 7.3L Power Stroke Diesel 26 08-01-2012 11:08 PM
Single Shot Sticks - Share Stories! Tugly 1999 - 2003 7.3L Power Stroke Diesel 17 07-12-2012 10:20 AM
Stinky's new HPOP - the adventure continues Tugly 1999 - 2003 7.3L Power Stroke Diesel 11 05-04-2012 07:11 AM
Pulled the trigger and WHOOSH! Tugly 1999 - 2003 7.3L Power Stroke Diesel 14 04-11-2012 09:29 AM
Tags
12, 73, air, article, autoenginuity, circle, communications, condition, conditions, dashboard, diagram, established, ford, iowa, powered, road, unit, vbulletin, volt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
