AE (AutoEnginuity) Beginner-Advanced!
#61
If you ask specific questions here... like "Why can't I open the recorded file in Open Office and make a graph?", someone can chime in and help. If you have a graph and try to decipher what it's saying about your engine, do what I do and share it here. Having everybody look at the graph and learning at the same time is a good thing.
Get plenty of data while it's running well. You will then recognize something out of place quicker if you have a problem in the future. I found an issue I wasn't even looking for - I helped a friend with AE and I saw his truck doing something better than mine.
#62
looking for a little help on a sunday. AE software won't connect to com port. Have used it a few times without a problem. I see device in device manager. comport 1 is set. key on etc etc. using the right settings from strictly diesel site non obd II etc etc. Still no joy. tRied to do firmware on the proline and it failed so thinking the proline connector might be bad. All lights on it work. Im stumped. Gonna be calling AE in the AM. oh yea also tested on 3 fords today and same result. running 9.1.1
#63
#66
#67
#68
#69
Once I know which one you have, you can either send me a file you want graphed or I can send you one of mine with a graph to copy and paste into your spreadsheet. Once you've copied it, you just change which cells in your spreadsheet are referenced in the graph.
I have a template I've made for my tune tests. Every time I do a run to test the tune under different driving conditions or a different tune, I just copy the template and change the cell references. This saves me from making a fresh graph every time and the graphs are easier to compare because they use the same format.
#71
Ok dumb question - I'm probably going to buy AE this summer and install on an old laptop ... which will get replaced around the end of the year I hope. But I'd like to keep AE on the old too and let that ride around in the truck (you know, just in case). Thought I saw something on the AE website about multiple machines - so would I just need to keep the security dongle with whichever PC I plan to use?
#72
#73
Which spreadsheet software are you using?
That is precisely what I'm already doing. My netbook doesn't even have a disk drive, I just copied the disk to a USB drive and onto the netbook. I have used my activation code on my 3 laptops and I just keep the dongle with the vehicle.
