AE (AutoEnginuity) Beginner-Advanced! - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 03-29-2012, 06:04 AM
Tugly's Avatar
Tugly Tugly is offline
I'm a cautionary tale.
Tugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputation
Quote:
Originally Posted by UcaN View Post
Thanks....that helps out a lot. Looks like i've got some homework to do.
If you ask specific questions here... like "Why can't I open the recorded file in Open Office and make a graph?", someone can chime in and help. If you have a graph and try to decipher what it's saying about your engine, do what I do and share it here. Having everybody look at the graph and learning at the same time is a good thing.
Get plenty of data while it's running well. You will then recognize something out of place quicker if you have a problem in the future. I found an issue I wasn't even looking for - I helped a friend with AE and I saw his truck doing something better than mine.
  #62
Old 05-20-2012, 06:24 PM
ajohansson ajohansson is offline
ajohansson is starting off with a positive reputation.
looking for a little help on a sunday. AE software won't connect to com port. Have used it a few times without a problem. I see device in device manager. comport 1 is set. key on etc etc. using the right settings from strictly diesel site non obd II etc etc. Still no joy. tRied to do firmware on the proline and it failed so thinking the proline connector might be bad. All lights on it work. Im stumped. Gonna be calling AE in the AM. oh yea also tested on 3 fords today and same result. running 9.1.1
  #63
Old 05-21-2012, 06:17 AM
Tugly's Avatar
But it is OBDII. Non OBDII would be something more like a CAN network (possibly replace OBDII in the future), which these can also handle with upgrades. I think vehicles should just go straight-up USB, but the manufacturers might protest such easy access to their vehicles inner workings.
  #64
Old 05-21-2012, 12:46 PM
bearman113 bearman113 is offline
Alaska Chapter Leader
bearman113 is starting off with a positive reputation.
Subscribing
  #65
Old 05-22-2012, 06:22 AM
Tugly's Avatar
This was a few posts back and some time ago, but these are the settings in my AE software for making connection.
  #66
Old 05-22-2012, 09:34 PM
Well i talke to AE and they think the proline is "scrambled". I sent it in today for them to fix under warranty. Also going to upgrade to 10.1 while I'm at it. Will report back what the deal is.
  #67
Old 05-23-2012, 06:19 AM
Tugly's Avatar
Quote:
Thanks for that feedback! I'm curious how that turns out.
  #68
Old 05-23-2012, 07:55 PM
2000ca250 2000ca250 is offline
2000ca250 has a good reputation on FTE.2000ca250 has a good reputation on FTE.
Tugly,
How do you get the information into a graph outside of AE....I have a bunch of data in spread sheets but I cannot figure out for the life of me how to turn it into decent readable graphs
  #69
Old 05-24-2012, 06:04 AM
Tugly's Avatar
Quote:
Originally Posted by 2000ca250 View Post
Tugly,
BOOM! That's a big'n. I take it you have spreadsheet software like Excel or Open Office. Which one do you use? I can do screen shots of how to get started.
Once I know which one you have, you can either send me a file you want graphed or I can send you one of mine with a graph to copy and paste into your spreadsheet. Once you've copied it, you just change which cells in your spreadsheet are referenced in the graph.
I have a template I've made for my tune tests. Every time I do a run to test the tune under different driving conditions or a different tune, I just copy the template and change the cell references. This saves me from making a fresh graph every time and the graphs are easier to compare because they use the same format.
  #70
Old 05-24-2012, 08:43 AM
UcaN UcaN is offline
UcaN is gaining momentum as a positive member of FTE.UcaN is gaining momentum as a positive member of FTE.
I'd like one Tugly..... I have a few runs i want to graph.....
Thanks.
  #71
Old 05-24-2012, 10:28 AM
GoCamping's Avatar
GoCamping GoCamping is offline
GoCamping is gaining momentum as a positive member of FTE.GoCamping is gaining momentum as a positive member of FTE.
Ok dumb question - I'm probably going to buy AE this summer and install on an old laptop ... which will get replaced around the end of the year I hope. But I'd like to keep AE on the old too and let that ride around in the truck (you know, just in case). Thought I saw something on the AE website about multiple machines - so would I just need to keep the security dongle with whichever PC I plan to use?
  #72
Old 05-24-2012, 11:00 AM
Quote:
i believe that is the case
  #73
Old 05-25-2012, 01:22 AM
Tugly's Avatar
Thanks.
Which spreadsheet software are you using?
That is precisely what I'm already doing. My netbook doesn't even have a disk drive, I just copied the disk to a USB drive and onto the netbook. I have used my activation code on my 3 laptops and I just keep the dongle with the vehicle.
  #74
Old 05-25-2012, 06:17 AM
Good morning
I use Excel......
  #75
Old 05-26-2012, 06:51 AM
Tugly's Avatar
I'll round that up after the holiday weekend.
My luck soots Stinky just fine... Brisk Buck$Zooka Blasts! Tugly 1999 - 2003 7.3L Power Stroke Diesel 106 12-04-2012 07:14 AM
For Those Considering Big Exhaust! Tugly 1999 - 2003 7.3L Power Stroke Diesel 110 10-24-2012 04:51 AM
Only I can make such a mess... help! Tugly 1999 - 2003 7.3L Power Stroke Diesel 26 08-01-2012 10:08 PM
Single Shot Sticks - Share Stories! Tugly 1999 - 2003 7.3L Power Stroke Diesel 17 07-12-2012 09:20 AM
Stinky's new HPOP - the adventure continues Tugly 1999 - 2003 7.3L Power Stroke Diesel 11 05-04-2012 06:11 AM
Tags
12, 73, air, article, autoenginuity, circle, communications, condition, conditions, dashboard, diagram, established, ford, iowa, powered, road, unit, vbulletin, volt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
