New pedestal and a new oil leak
Old 03-03-2012, 07:55 AM
spongecop's Avatar
spongecop
spongecop is offline
Semper Fi
Two weeks ago I replaced my ebpv ped with a new non-ebpv one. Recently developed a leak that is coming down the rear of both heads, meeting at the trans insp cover and onto the ground. Check the turbo to ped and it's dry. Ped looks dry but I fear it's leaking where the ped goes to the block. I put new vitrion o rings and cleaned it up real good. Are these prone to leaking or seeping outright? Seems to leak as its cooling down after driving. Man I don't want to take all that apart again?
Old 03-03-2012, 07:59 AM
F350-6's Avatar
F350-6
F350-6 is offline
What did you torque the pedestal down to? If you pinched one of the o-rings, then it may be leaking.
Old 03-03-2012, 08:02 AM
spongecop's Avatar
spongecop
Semper Fi
18 ft lbs. I was real careful....I thought....when I put it on. Can't imagine I pinched the o ring cause the ped is so light compared to the turbo. May try a put a box end wrench on the rear bolts and give them a little more torque.
miller_feed's Avatar
miller_feed
miller_feed is offline
Hook it, I'll pull it.
It could be that when you put the pedestal on the block, you rolled an 0-ring. This will happen if you don't come straight down with the pedestal. Same thing can happen when you put the turbo back on the pedestal.
Take the spider off and get a good look where the oil is coming from.
Old 03-03-2012, 08:05 AM
spongecop's Avatar
spongecop
Semper Fi
Ok. Just picked up some new hpop lines yesterday so I panned on washing it down real good after that. I did notice the intake inner edges are wet on both sides. I wonder if something else may be leaking and running down and off the rear of the heads.
Plus it went 7 days and three hundred miles after I installed everything before it started leaking....if it is the ped.
Old 03-03-2012, 10:13 AM
HeatStroked's Avatar
HeatStroked
HeatStroked is offline
did you have the leak before you replaced it?
Old 03-03-2012, 10:20 AM
spongecop's Avatar
spongecop
Semper Fi
Not from drivers side. Ebpv was leaking before which is why I deleted it. It's just puzzling why, if it is the pedestal to block, that it lasted for 7 days and 300 miles.
Thinking now though the passenger side was leaking and still is. I thought it was the ebpv pedestal. Maybe it wasn't. ?
Old 03-03-2012, 10:29 AM
HeatStroked
Pull it, check it, new O rings, re-install.
BTW, I have used thicker, oversized O rings in the past, sometimes the stock ones barely rise above the seat cut in the pedestal and will not provide a good seal between the pedestal and turbo and can leak again over time.
Old 03-03-2012, 10:35 AM
spongecop's Avatar
spongecop
Semper Fi
Thought about that. When I went to install it I thought they were shallow on the block...dang it!
Does Bob sell the oversized o rings?
Old 03-06-2012, 04:34 PM
spongecop's Avatar
spongecop
Semper Fi
UPDATE:
Washed top of valley and looked for source of my leak. Snugged down my Hpx it make sure it was not that... Im in Dallas and the weather has warmed significantly especially over night. Now the leak has slowed almost to nothing. I assume the pedestal to block is more suseptable to temp changes since thats what slowed/accelerated my EBPV leak. Any thoughts from the group?
Also does anyone have any info on the oversized o-rings mentioned in the earlier reply?
Old 03-06-2012, 05:18 PM
HeatStroked
Originally Posted by spongecop
UPDATE:
Got the over sized O rings from KCM Diesel
Cell's
05-06-2015 10:57 PM
bigb56
22
05-12-2012 09:10 PM
meierw1
05-08-2012 01:59 PM
Shade
07-07-2008 02:21 PM
Hiflyer746
08-24-2006 03:52 PM
Quick Reply: New pedestal and a new oil leak
