7.3L PSD with propane? - Ford Truck Enthusiasts Forums
Old 04-26-2003, 12:11 AM
twags6's Avatar
twags6 twags6 is offline
PAA Member #7 and FTE
twags6 has a very good reputation on FTE.twags6 has a very good reputation on FTE.twags6 has a very good reputation on FTE.twags6 has a very good reputation on FTE.
Smile 7.3L PSD with propane?
I'll be getting a 97 f-250 HD extended cab swb with a 7.3L PSD and 5 speed manual trans and was wondering what the advantages of adding propane would be? The truck has a gooseneck hitch installed and i might use it to tow a trailer at some time.
Thanks for the advice
Trevor
Old 04-26-2003, 05:08 AM
Quadzilla's Avatar
Quadzilla Quadzilla is offline
Quadzilla is gaining momentum as a positive member of FTE.Quadzilla is gaining momentum as a positive member of FTE.
From all the sources I've spoken to, propane is the single biggest gain in power you can put on a diesel. It isn't the cheapest way to get power, but it is the most productive, with horsepower gains of 60-100 rwhp reported. It will make your truck run cleaner, and will also increase your mpg.
Though chips will advertise that they increase your power that much, the dyno proves otherwise.
Tags
2001, 73, 73l, adding, diesel, f250, powered, propane, psd
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
