You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I am very close to putting the order in for a brand spankin new 2012 F350 Extended Cab XLT DRW Chassie with the 6.2, But I have a few questions?
(First new truck I ever have purchased) I have never wanted to take the hit new but when they give you what you paid for your old truck you cant say no!
Should I get the 3.37's or 4.10's?
Its going to have a dump body on it and be towing/hauling every day and plowing snow in the winter with occasional interstate travel, what do you guys think?
Im upgrading from a 08 V10 chassie with the same specs. Can I expect an increase in milage, have you guys run E85 in them with any plus sides?
Is the sync system worth it?
Anything else I should be looking out for or things I should be aware of!
I wanted to go with the 6.7 but its too expensive! I plan on turning this thing back in at 60-100K for a new one. Maybe the next will be a diesel.
I was pretty impressed with the get up and go from the 6.2
Thanks in advance! Ill throw some pics up once she get upfitted in 9 weeks
__________________ Rob 2007 F-250 6.0 CC SB 4x4 Black Sport FX4 20inBlackBMF Novakane 8 W/ Toyo M/T 33x12.50x20 Stock Motor 2004 F-250 6.0 CC SB 4x4 Black Sport FX4 Sold-She was problem free.
You ask about is the "sync system worth it?" I will say defiantly " yes " and particularly for you because of the amount of time you are working in that rig,....give your self a little pleasure to make your day.
I figured it was nice, Just not sure about the price tag! Still torn on the whole gear ratio thing. Are the 3.73's going to be fine or am I looking into it too much.
I would think that under the conditions that you outlined,...primarily a WORKING TRUCK, you should go with the 4.30 gear ratio and expect to loose 1 to 2 MPG at highway speeds over the 3.73 millage but you would probably break even if you are working the truck and using the 6 speed transmission in the lower gears if you had the 3.73 verses the higher transmission gears with the 4.30,....so your call but I would go with the 4,30 and you will probably still get better overall millage than your current V !0 and have more power.
Here's my 2 cents. I ordered the 4.30 gears for my F350 to maximize the power. It sounds like guys with the 3.73 gears are having to run in 5th gear at a higher rpm while towing. I thought with the lower gears it would be able to stay in 6th gears running at a lower rpm to increase fuel economy. I will soon find out, it sounds like I should get it in 3 weeks.
