How To Test FICM With Scan Gauge - Ford Truck Enthusiasts Forums
Old 03-02-2012, 08:08 PM
mtnxtreme800 mtnxtreme800 is offline
mtnxtreme800 is starting off with a positive reputation.
Can someone give me the procedure for FICM test with my Scan Gauge, I think there is a check with key on, then cranking, then running, I can't even find FICM test on the Scan Gauge!?!?!
Old 03-02-2012, 08:18 PM
amdriven2liv's Avatar
amdriven2liv amdriven2liv is offline
I'm hitting easy street
amdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputation
You need to enter the gauges. The FMP is the main one.
FICM Vehicle Power (Volts) (Should be 12 Volts, should not drop below 10.25 for more than 60 seconds, or 9.0 for 4 seconds. TSB 09-24-03)
TXD: 07E02209CE
RXF: 0462450906CE
RXD: 3010
MTH: 006401000000
NAM: FVP
KO=12.0 LI=14.0 HI=14.0 OR=10.5-15.5
FICM Logic Power (Volts) (Should be 12 volts)
TXD: 07E02209CF
RXF: 0462450906CF
RXD: 3010
MTH: 006401000000
NAM: FLP
KO=12.0 LI=13.5 HI=13.5 OR=10.5-15.5
FICM Main Power (Volts) (Should be 47-48) Your FMP should never dip below 45. If it does, your FICM is toast and needs repaired or replaced.
TXD: 07E02209D0
RXF: 0462450906D0
RXD: 3010
MTH: 006401000000
NAM: FMP
KO=47 LI=47.5 HI=47.5 OR=40-52 (yes, that is what it says from Ford)
So, do the test engine cold, like over night. Have all your gauges in and ready on the screen.
Turn on the key, and watch the FMP. It shouldn't drop below 45v.
The FVP will show how your batteries are doing towards your FICM.
Are you having long crank times now?
Scangauge needs some crank time to really pick up those issues. If you are not having long crank times, you probably wont catch anything.
Old 01-03-2013, 12:39 PM
jeepsterjc jeepsterjc is offline
jeepsterjc is starting off with a positive reputation.
Lost my pids and now found them- Thank you
I replaced our ficm a couple of months ago (the solder job worked but the blown trace... I didn't want to trust a repair for that!) and everything about the wife's F350 was textbook perfect. Then... the cold weather arrived and the batteries were mismatched and read a volt low so I replaced them.
Then in my haste to read the first voltages after reconnecting the two new batteries in the dark napa parking lot I managed to delete one my my ficm pids- and I didn't use the suggested names and I forget what I had them set to so now after a super fast google search I've found your pids and Thank You Very Much.
Now they are going into the Scangauge and we have piece of mind again.
Happy New Year
Old 01-03-2013, 04:25 PM
It's good to start the new year with "piece of mind!"
Happy New Year!
05 Excursion No Start.. Scanner wont link for code CenCalGuns 6.0L Power Stroke Diesel 7 03-11-2014 07:17 PM
Glow Shift Quad Pillar? 99ExpyProblems 6.0L Power Stroke Diesel 26 10-09-2013 02:47 PM
What Did You Do to Your 6.0 Today? Mr. Sandman 6.0L Power Stroke Diesel 2 12-07-2012 08:00 PM
crank cam sensor retiredinstructor 6.0L Power Stroke Diesel 4 02-28-2012 04:45 PM
Code P0541? Rich in CO 1999 - 2003 7.3L Power Stroke Diesel 10 04-08-2011 12:43 PM
Tags
2003, 60, adding, check, diesel, ficm, gauge, ii, scan, scangauge, scanguage, superduty, test, tool, voltage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
