You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
What does the upper intake manifold have to do with the oil pan?
I intend on removing the oil pan on my 89' Bronco 5.0 tomorrow, cause I think some gasket material fell down inside when I replaced the timing chain. The reason I think so is cause now Im having intermittent oil pressure drops that I never had before so Im thinking the pick up screen is getting blocked. The Chilton's manual says I have to remove the upper intake manifold before I remove the oil pan, as well as drain the coolant and remove the fan shroud. What does one have to do with the other when they are on top and the front of the motor and Im working underneath? Seems like a waste of time to me
__________________ I'd rather be hated for who I am, than be liked for what I'm not ! 1989 Bronco XLT 5.0
When you are lifting the motor, if you go to far you can jam the plenum into the cowl. Loosening the shroud same thing. It gives you added clearance. If you lift the motor up what happens to the fan? Common sense really. You shouldn't have to drain the coolant unless you pull the Rad.
__________________
Matt - Ninja Edit Master
02 Excursion XLT V10 4WD - 12 Escape L4 XLT AWD - 99 Mustang 3.8L 'Vert - 96 Wilderness 22LW TT
JOIN THE WEST VIRGINIA CHAPTER CLICK HERE
Carlisle - 2012 Mid-Atlantic Meet - Pic Thread >>CLICK ME<<
I have found that Haynes and Chilton's manuals often list unnecessary steps. Some of it is no doubt because they will "cut and paste" procedures already written for another application. So I don't necessarily follow their instructions religiously.
Ok, now that makes sense! Thanks
Raise the engine carefully while having someone else watch the top, or check it yourself frequently. With a little luck you won't have to remove anything up top.
Realistically how high does it need raised to pull the pan?
I'd say 2" or maybe more. I never measured it but I've had to pull the intake to do one on my dads truck(5.0L), but not on mine (4.9L). The upper fan shroud comes right off so there's no point in chancing breaking it.
And I've never had to drain coolant.
__________________
Steve
'96 F-150XL Reg Cab Long Box 5.8 M50D 4X4 6" Skyjacker lift with extended radius arms. 33" tires. 3.55's with front and rear auto lockers. Swaped in Quad shocks, V8, BW 44-07 transfer, power windows, locks, mirrors, tilt wheel, speed control, and tach.
'97 F-350XL 5.8 E4OD Chassis Cab
How far you raise it is a matter of how good a contortionist you are. To get the pan completely off, in addition to raising the engine, you need the exhaust out of the way and you will need both the oil pump pickup and the pump dropped into the pan. Then the pan will slide back and down far enough to come out.
__________________
Bill Vose (Old School Hot Rodder) 1986 F350 crew cab DRW 460ci EFI, E4OD, PMGR starter, 160 amp 3G alternator, 12X3 rear brakes, Traction lock 3.55
1995 Lincoln Continental (project car), 1994 Taurus LX (daily driver) http://www.oldschoolhotrodder.com
"growing old is inevitable, growing up is optional"
Ill get at it tomorrow when its 20 degrees warmer out, supposed to hit about 60.
I took a look as I was draining the oil and it doesnt appear that the exhaust will be in the way any, but I could be lookin at it the wrong way
Someone correct me if I am wrong, but that would have to be one heck of a BIG piece of gasket to block off the oil pickup screen. I am doubting that's your problem. Anyone?
Im not sure its the problem either. But the intermittent oil pressure drops didnt start til after I replaced the timing chain. It only drops after I drive and get the motor hot. the distance and time it takes varies. It only drops when Im coming to a stop and starts to idle down. Although it doesnt seem to do it when its in Park or neutral, only in gear
Well since you are taking the pan off, now would be a GREAT time to replace the oil pump. How many miles on it? Just trying to help out!
