Shifting no vacuum
Old 03-10-2012, 03:09 AM
diablodude64's Avatar
diablodude64
diablodude64 is offline
Shifting no vacuum
I have been trying to diagnose my shifting issues on my 87 f250 6.9. It has a c6 and basically when i'm driving normal it won't shift with out nearly hitting redline. So, I pulled the vacuum hose at the modulator and while idling, it has no vacuum there.
What should I check?
Thanks, Kyle
Old 03-10-2012, 07:55 AM
subford's Avatar
subford
subford is offline
Deleted
Deleted
Sorry I did not notice it was a Diesel.
Old 03-10-2012, 07:56 AM
bashby's Avatar
bashby
bashby is offline
Does your power brake assist work? If not you probably need a vaccum pump. If it does follow the lines around that that go to the modulator looking for leaks.
cabloom300
28
12-02-2014 11:08 AM
HillBillyBuddha
03-13-2014 04:25 PM
JSKIER24
10-09-2008 02:11 PM
isottoman
12-13-2006 04:30 PM
ole_crow
07-13-2005 06:29 PM
Quick Reply: Shifting no vacuum
