Daytime Running Lights
#35
#36
Well here is what went down.
I showed them the paperwork and instructions. I stood there watching the laptop, we get down to the DRL and there are 2 and only 2 options:
1: NONE
2: Low beams only
So we selected Low beams only and that is exactly what you get.
Bottom line is they were correct, there no option for Amber DRL or anything other than low beams...
You can turn on your DRL from the dash using this procedure:
"The system switches the headlamps on with a reduced output in daylight conditions.
To switch the system on:
1. Switch the ignition on.
2. Switch the lighting control to the off, or parking lamp position.
3. Disengage the parking brake.
4. Make sure the transmission selector lever is not in position P."
Page 68, 2015 owners manual, 3rd printing.
1: NONE
2: Low beams only
#38
#39
#40
#41
In my world they are lights at each end and each side of the vehicle, but does not include headlights.
#42
you are correct, can be amber.. only forward facing
#43
#44
#45
Yes, that is called dark mode. It can be programmed via the SJB. Mostly used on police style vehicles.
