95 f350 wont pull fault codes - Ford Truck Enthusiasts Forums
Old 03-02-2012, 03:36 PM
spartan29307 spartan29307 is offline
spartan29307 is starting off with a positive reputation.
I can't seem to pull fault codes even though it says there are 124 of them.
Throttle position sensor registers 68.6% at any engine speed. I have replaced MAP sensor, cam position sensor and speed sensor and still get CEL, along with very harsh up and down shifts. When CEL light off the vehicle surges and will quit running at low speeds, at higher speeds it will stumble until CEL comes on and will run fine except the shifting problem. also coolant temp registered 276 deg. but the engine was only running for 2-3 minutes at that time.
If anyone has any ideas what is the cause of this before I buy any more sensors I would appreciate it.
Old 03-02-2012, 04:53 PM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
Your pcm may need to be flashed (updated) to pull the codes from the obdII port, otherwise you may need to get them from under the hood (obdI) I think. I'm not much more help than that, if that is any at all.
Welcome to fte, and bump up for more help if nothing else.
Old 03-02-2012, 05:06 PM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
Sounds like your using a scanner that's didn't read PSD's If I hook mine up to a autozone scanner it shows that I have 100+ codes
Old 03-02-2012, 05:13 PM
Thanks Mike, didn't think of that. I've never even tried to have one of them places try mine I guess.
Old 03-02-2012, 07:12 PM
Hussler's Avatar
Hussler Hussler is online now
Hussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to all
Unplug the ICP sensor and see if the surging and or stalling goes away, cel light will come on but that's expected. On a side note if I had 124 fault codes then I would probably drive the truck to the cliff and push it off ... heck, we only have a half dozen sensors.
Old 03-02-2012, 09:54 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Now Jim, we all know you wouldn't do that! LOL Do scan gauges work with 95's? Welcome!
Old 03-02-2012, 10:42 PM
stainlessstroker95's Avatar
stainlessstroker95 stainlessstroker95 is offline
stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.
Quote:
Yes scan gauges work on 95. I am glad i got mine.
Old 08-15-2014, 03:05 AM
hammersjl hammersjl is offline
hammersjl is starting off with a positive reputation.
I know this is an older post but did you figure out what the problem was? I am currently having the exact same issue and I'm trying to avoid taking it to the stealership if I can.
Thanks
Jared
97 auto ts 6 pos
Old 08-16-2014, 10:53 PM
B Big's Avatar
B Big B Big is offline
B Big is starting off with a positive reputation.
When you pull the plug off the ICP you might find oil in the plug end and if that is the case the ICP is bad. Mine was and after I replaced it my truck ran and shifted better.
pip sensor fault code stevenjf88 1987 - 1996 F150 & Larger F-Series Trucks 9 06-16-2015 08:03 PM
'95 F53 7.5 Super Duty EGR fault code jdr37 1987 - 1996 F150 & Larger F-Series Trucks 1 11-07-2014 08:00 AM
92 F150 CEL Code Issue 5.0L offrdmania 1987 - 1996 F150 & Larger F-Series Trucks 9 09-24-2014 12:04 PM
engine runs better with egr vac line removed and sensor unplugged seanthero Ford Inline Six, 200, 250, 4.9L / 300 7 07-26-2014 07:05 AM
Code 172....I need some ideas. digicon 1987 - 1996 F150 & Larger F-Series Trucks 16 06-04-2014 01:10 PM
Tags
1997, 73, 95, chip, codes, f250, f350, ford, located, powered, pull, scangauge, trouble, vbulletin, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
