hanging transmission filter
Old 03-02-2012, 11:16 AM
econobug's Avatar
econobug
econobug is offline
hello;
I was wondering if a transmission filter that hangs down would have the same impact as one that fell off.
I had lost reverse, but regained it, only to lose drive the following week.
I do have a form of drive but I lack any form of power on even the slightest inclines.
I removed my transmission pan and noticed that the filter was hanging down, and was wondering if this was perhaps the cause of losing drive.
Thank you,
econobug
_________________________________
1990 Ford Econoline E250
351 Windsor
E4OD
Old 03-02-2012, 11:49 AM
joshofalltrades's Avatar
joshofalltrades
joshofalltrades is offline
did you check the fluid level before you pulled the pan? low fluid could cause this.
i haven't studied the e4od, but many trannys have the filter almost touching the pan anyway, so having it loose would only be 1/8" lower and still getting fluid into the system.
Old 03-02-2012, 11:51 AM
blageurt's Avatar
blageurt
blageurt is offline
definitely the cause...you were sucking air into the sytem ... the filter just presses into place...Did you replace it ?
Old 03-02-2012, 12:10 PM
econobug's Avatar
econobug
econobug is offline
Thank you both for your responses.
Yes, joshofalltrades, I did check the level. It was okay.
And, blageurt, I shall get a new filter, hopefully today, from a Ford dealership. The filter in the van, is not a Ford product, but is identical in all respects. I shall probably get the clip for the filter also.
I shall let all know if this cured my problem.
Thanks again,
econonbug.
Old 03-02-2012, 12:26 PM
econobug's Avatar
econobug
econobug is offline
hello again;
Just called the local Ford dealership. The filter costs $58.00 and change. The gasket costs $20.00 and change. They have the magnet that goes between the filter and pan to stop it from hanging. It is $12.00 and change.
I shall get the magnet to hold the filter in place, and take it from there.
Again, thanks.
econobug
Old 03-03-2012, 04:03 PM
econobug's Avatar
econobug
econobug is offline
hello again;
the Ford dealership did not have the magnet after all. For those who are interested, it is p/n YS7Z7E290AA.
They told me it would take 4-5 days to arrive at a cost of $45-$49. (I heard the sound of forty and I forgot the rest).
Anyway, I picked up the Ford transmission filter. They gave it to me for $48.00.
I hope this is the cure.
Shall keep all informed.
econobug
Old 03-04-2012, 12:37 AM
maples01's Avatar
maples01
maples01 is offline
Just find a magnet at a hobby shop that is the needed thickness and install it, that's robbery.
Old 03-04-2012, 05:39 AM
econobug's Avatar
econobug
econobug is offline
here is more info on this magnet
http://web.archive.org/web/200107271...etins/t037.gif
the part number shown is the old one.
1happycamper
1999 to 2016 Super Duty
04-12-2018 08:44 AM
silverbullet6oh
05-01-2016 01:59 PM
bikeymikey
08-04-2011 10:50 AM
Farmboypowerstroke
05-10-2010 09:58 PM
linckeil
16
09-17-2009 12:03 AM
Quick Reply: hanging transmission filter
