Exhaust for V-10
well if you your V-10 to have any decent sound you have to eliminate the factory cat, its a huge sound deadener. I started my truck with just the cat and it was really quiet. I had a local shop eliminate the cat, put on a Flowmaster 80 series muffler, 3" in, dual 2.5" out and out on each rear corner. Its got some volume when u jump on it but dont hear it at all during normal driving. Gotta warm ya thou, its not a deep rumble you would expect, it sounds like a corvette or Lambo. It only ran me around 500 installed. Hope that helps. Im slacking on posting the sound, hopefully soon.
I run the Banks Torque Tube system on my V10...
System includes, Headers, less restrictive Y-pipe, Heat Shields and all stainless hardware.
Running OEM Cat ( which is not very restrictive).
Into a Magnaflow full size 3" in by 2x3" out, pipes are all Stainless 3".
Nice rumble at idle, wakes up when you wanna burn some Gas and Rubber!
I have the Gibson exhaust on my Jeep TJ, on my 3rd header.
My Gibson keeps cracking at the weld spots.
When I decided to do the EX last year and looked at the amount of labor involved... It was a no brainer for me not to use Gibson. So that left me just a few options.
I can recommend the banks, no leaks, no issues!
I've heard a few good clips on and might look into this one cherrybomb extreme on F250 V10 - YouTube
The only reason I went to headers is that I had a couple broken exhaust studs, so figured WTH and replaced everthing.
https://www.ford-trucks.com/forums/1...r-dummies.html
