Go Back   Ford Truck Enthusiasts Forums > Marketplace > Want to Buy > WTB - Parts & other
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
WTB - Parts & other Want to buy parts/accessories/tools.
  #1 (permalink)
Old 03-02-2012, 03:18 AM
JMM-MD's Avatar
JMM-MD JMM-MD is offline
2000 Ford Excursion
JMM-MD is starting off with a positive reputation.
99 F250 SD steering knuckles
Got to do the ball joints on my 250 SD (99) and Exc (00), want to set up the knuckles before I do the tear down since I do not have a press, and I want to do as much as I can to make sure that once I start on one I can start and finish in a single day.
Looking for the front steering knuckles (both sides), the piece(s) that have the ball joints, both are 4X4 - how much shipped to 21755?
__________________
See Ya!
00 Excursion
99 250SD
  #2 (permalink)
Old 03-02-2012, 03:33 AM
stemo76's Avatar
stemo76 stemo76 is offline
1999 Ford F-350
stemo76 is starting off with a positive reputation.
https://www.facebook.com/profile.php?id=100000160923877 whatusaytome http://www.linkedin.com/in/stephenemorrison cornholio0076
I would suggest going to the auto parts store and renting the ball joint press tool My local stores will rent for free. Do one side one day and the other the next.
Also be sure to get all the seals and o-rings needed for the job.
2 4C3Z3049DB Grease-able upper ball joints(may need a 90 degree zerk to clear)
2 5C3Z3050E Grease-able lower ball joints
2 F81Z4A322AA Yellow orings
2 F81Z3254CB Seal
2 F81Z1S175HCA Wheel seal
2 EOTZ3K050B lower ball joint snap ring
2 F2TZ3A049A Upper ball-joint nut
2 F2TZ3A050A lower ball-joint nut
1 4C3Z1K106AA oring kit (includes 1 snap ring and two black hub seals)
4 13507 Cotter pins
  #3 (permalink)
Old 03-03-2012, 06:12 AM
JMM-MD's Avatar
2000 Ford Excursion
Thanks for the parts list! That is great, I was putting that together with plans to gather all the parts I could possibly need and have therm here before I started - this is great! The one thing that was on my list and not yours were the wheel berrings - the one truck has almost 100k on it and the 2nd has 150k on it, should I be looking at replacing the wheel berrings while i have the front end torn down?
The thing is - I typically will get one day on the weekend for this kind of thing - if I cannot get it done in a single day it will most likley span multiple weekends do not want to do that. I will check the local auto parts store to see if they have the ball joint press and what they want to rent one - I know the Advance Auto stores around here will lend tools and the last time I used them it took me t trips to the store since the first tool ended up missing some parts, but I did eventually get one that I was able to get the job done with.
__________________
See Ya!
00 Excursion
99 250SD
  #4 (permalink)
Old 03-03-2012, 06:29 AM
stemo76's Avatar
1999 Ford F-350
I think that you will find the wheel bearing unit very expensive. Probably want to check it out and replace when needed rather than preventive maintenance. I was able to do both in a single day. If you can't find a rental place check out harbor freight. If your not familiar they sell crappy version of tools. Many are not worth their weight but something that your going to use once or twice and then store they work fine. That is where mine came from and I have used it several times.
If you have a spare set of knuckles I don't think you will gain more then maybe 15 - 30 minutes on the project. Most of the time is going to be in the removal of the knuckle and reinstall of it. Pressing in the ball joints is pretty quick with the tool.
__________________
Early 99 PSD Dually Crew 4x4. Super lift leveling kit - Converted to late Turbo and intake - Banks exhaust with power elbow - Ford AIS Severe Duty - Swamps HP IDM - Banks TransCommander - Triple Gauge pillar with Autometer gauges - Column mounted HPOP gauge - DieselSite fuel CPR system - DieselSite Adrenaline HPOP - FS2500 bypass oil filter - Rosewood stage II split shot injectors - PHP custom tuning - 19.5 Vision Wheels (Not Recommended)
  #5 (permalink)
Old 03-03-2012, 06:41 AM
JMM-MD's Avatar
2000 Ford Excursion
Something to think about....
__________________
See Ya!
00 Excursion
99 250SD
Tags
2003, 2004, 2008, 4x4, 99, f250, ford, hoses, knucke, knuckle, removal, sd, seal, stearing, steering, superduty
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
