Build Thread: '49 F321 - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 03-02-2012, 11:40 PM
preppypyro's Avatar
preppypyro preppypyro is offline
Posting Legend
preppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud of
For what its worth, i love it when guys use stuff they have collected over the years to aid in their vehicle builds. Jeff have you ever checked out the rattle can rebuild on "the hamb"? Sounds right up your alley!
  #32
Old 03-03-2012, 12:32 AM
ben73058's Avatar
ben73058 ben73058 is offline
ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.
Hey Jeff,
I'll post up a pic of our steering linkage - It would make the
great pyramid builders jealous. I think I may have your steering contortions beat but let's see. I've got the same 351W fitting into the shoebox '48-'52 trucks.
I was amazed out how expensive all the aftermarket steering stuff
was... I couldn't swallow the Ididit $700 column - I went with some knockoff & I've been paying for it since. I like your Bronco II solution - I looked around at used steering columns on Ebay - they wanted even more for the reconditioned old ones.
You are coming along great. What's your plan for F1 fenders. I went with fiberglass finally & they are nice & not too costly. I think I would have been a year trying to get all that bondo fixed up - just wasn't worth it - I think I paid around $200 per fender.
Your boy looks to have shot up past you - I was doing pretty well with my 20 year old son Zack - then he kept growing into college - got me by a good 4 inches now. Nice family - I'd faint if my wife came out to work on the truck.
Ben in Austin
  #33
Old 03-03-2012, 11:18 AM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
To save the oil change sticker try using a hair dryer or heat gun and a scraper underneath the sticker. Take your time and be careful. You can also take a high-resolution digital image of the sticker, crop it on your computer and print it out. It'll look practically the same.
  #34
Old 03-04-2012, 09:55 AM
barnfind 51's Avatar
barnfind 51 barnfind 51 is offline
barnfind 51 is starting off with a positive reputation.
Hey Jeff what is the final height of your front end with the Jag? How many inches from bottom of frame rail to ground? Also what size tires are you going to be running? Also your motor mounts look great! Looks like some beef to me. George
  #35
Old 03-04-2012, 10:05 AM
tinman52's Avatar
tinman52 tinman52 is online now
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
Great "do it yourself build"! You are making good progress, will be watching.....
  #36
Old 03-04-2012, 10:07 AM
Jeff and Nicolle's Avatar
Jeff and Nicolle Jeff and Nicolle is offline
Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.
Quote:
It's sitting at 9" IIRC from the bottom right now, but not all the weight is on it yet. Tire size is 235/60/15, but I might use something different. And I hope the engine mounts are as strong as they look, because I like them!
More to come, just dealing with a motor issue right now...
  #37
Old 03-10-2012, 10:55 PM
Taking the cab off
  #38
Old 03-10-2012, 10:59 PM
Floor repair, not much though!
  #39
Old 03-10-2012, 11:02 PM
After the minor repairs, i coated the bottom with CHASSIS SAVER.
I will add a picture when i find one! Sorry..
  #40
Old 03-10-2012, 11:15 PM
I bounce around sometimes to see something different. So here is some rear fender repair. I don't have the best mig welder, but it does the job.
  #41
Old 03-10-2012, 11:18 PM
More on the rear fender repair
  #42
Old 03-11-2012, 08:27 AM
Quote:
Very nice my friend looking good!! Buz
  #43
Old 03-11-2012, 09:28 AM
I welded that up with the old buzzy!
  #44
Old 03-11-2012, 10:13 AM
topmoo's Avatar
topmoo topmoo is offline
topmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant future
Looks great, and nice to have all that help too. I should have looked harder for u-joints, I paid the big bucks for mine.
  #45
Old 03-11-2012, 10:52 AM
ben73058's Avatar
Hey Jeff,
That's not floor "repair" that's floor perfection! I don't see any rust anywhere. Looking good over there! I like what you did with your fenders - I was lazy & bought fiberglass ones after encountering work by "The Bondo King" - (Previous owner).
Ben in Austin
Call out to you 5.0 EFI users Jeff and Nicolle 1948 - 1956 F1, F100 & Larger F-Series Trucks 19 01-30-2016 06:34 PM
Checking in and introducing Jeff and Nicolle 1948 - 1956 F1, F100 & Larger F-Series Trucks 26 05-12-2014 07:16 PM
'48-'50 F1 front fender measurement needed Jeff and Nicolle 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 03-17-2013 09:58 AM
'95 5.8L efi going into my '49 pickup Jeff and Nicolle 1987 - 1996 F150 & Larger F-Series Trucks 34 11-30-2011 10:46 AM
'95 351W/5.8 efi rated hp? Jeff and Nicolle 1987 - 1996 F150 & Larger F-Series Trucks 2 11-30-2010 12:57 PM
Tags
article, building, clubs, code, dakota, dashboard, michigan, north, ohio, powered, sale, salvage, skidoo, snowmobile, snowmobiles, vbulletin, wisconsin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
