No spark - Ford Truck Enthusiasts Forums
No spark
Old 03-01-2012, 08:52 PM
Morg89's Avatar
Morg89 Morg89 is offline
Morg89 is starting off with a positive reputation.
No spark
My 1984 f150,4.9 was running smooth down the road yesterday and then just suddenly shut off. Like toe tag dead. Thought maybe clogged fuel filter so replaced them all. No joy. Replaced dist cap, rotor, and even the coil. Still no spark. Engine turns great, fuel is flowing, just no spark... Any ideas.. Thanks
Old 03-01-2012, 09:58 PM
Harte3 Harte3 is offline
Harte3 is gaining momentum as a positive member of FTE.Harte3 is gaining momentum as a positive member of FTE.
Ignition module quit.
Old 03-01-2012, 11:59 PM
kedwinh's Avatar
kedwinh kedwinh is offline
kedwinh is gaining momentum as a positive member of FTE.
Quote:
X2 on that.
Old 03-02-2012, 11:11 AM
JimsRebel's Avatar
JimsRebel JimsRebel is offline
JimsRebel has a very good reputation on FTE.JimsRebel has a very good reputation on FTE.JimsRebel has a very good reputation on FTE.JimsRebel has a very good reputation on FTE.
Check to see if the rotor is still turning when you crank it over.
Old 03-02-2012, 11:30 AM
Morg89's Avatar
thanks for the info. I'll check for rotor rotation and then check the ignition module. I guess the ignition module would be cheaper than distro...
Old 03-02-2012, 11:38 AM
JimsRebel's Avatar
Dist. is only about $45 exchange.
Old 03-02-2012, 01:46 PM
AbandonedBronco's Avatar
AbandonedBronco AbandonedBronco is offline
AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.
You can pull the ignition module out and take it down to a parts store. They can check them for free.
Old 03-02-2012, 02:22 PM
gfw1985's Avatar
gfw1985 gfw1985 is offline
Cranky Old Guy
gfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to all
Your choice, buy parts and maybe fix it or troubleshoot it. I'd verify you are getting voltage to coil in start and run position first.
Old 03-02-2012, 07:43 PM
Morg89's Avatar
Yep, Ignition Module was the problem. It pays to trouble shoot. Replaced rotor, coil, distro cap and even before all that...fuel filters... I would advise any rookies to old ford trucks ,like me, that the Ignition Module is fairly cheap... 20.00$ or so at O reilley's... BUT while your in there go ahead and get the "special tool" to get the damn thing off. It is basically a 7/32 deep socket that is specially made to reach inside the deep holes holding the module on. No, all standard SAE sockets will not work because they are too fat to fit inside the deep holes. From there I would advise connecting the bottom front bolt first (the one closest to the radiator) and then the rear top bolt last.
Old 03-03-2012, 12:04 AM
kedwinh's Avatar
Kind of thought that's what it was. And at the price I started carrying a spare. Just a false sense of security for me. Glad you got it running again.
Old 03-03-2012, 06:04 AM
Morg89's Avatar
That is one dirty engine. It gets a good washing today before I have to work on something else.
Old 03-07-2012, 07:25 PM
Morg89's Avatar
http://i1262.photobucket.com/albums/...an1721/ICM.jpg
Mr. Lurch; I tried to send these to you but had no luck.
Old 03-07-2012, 07:29 PM
Morg89's Avatar
Old 07-17-2012, 04:57 PM
derr_eng derr_eng is offline
derr_eng is starting off with a positive reputation.
I just had the same problem as described above with my 93 econoline. I didn't buy a ton of parts to start replacing though.... I pulled the distributor and the rotor is not turning. Being new to ford I thought timing chain, O CRAP! But the more I read and investigate I guess these model engines do not have timing chains.... Anyone ever seen this before and also I can not turn the rotor by hand either. Please help....
Old 07-17-2012, 05:40 PM
JimsRebel's Avatar
Quote:
Just to be clear, you pulled the distributor CAP and the rotor did not go round and round when you cranked it over... correct??
When this happened to me I could turn the rotor very easy by hand. You will still need to remove the distributor and look closely at the roll pin/shear pin on the Distributor gear to see what is going on.
Be carefull, my distributor gear is still in the bottom of the oil pan.
Jim
Is my PCM the culprit? OldGoldie 1987 - 1996 F150 & Larger F-Series Trucks 32 01-17-2017 09:28 PM
Have spark and fuel but no start brandonnichols 1987 - 1996 F150 & Larger F-Series Trucks 14 01-08-2014 12:12 AM
97 f150 4.6 no spark. traumahawk351 1997 - 2003 F150 5 05-07-2012 02:14 PM
390 No Spark? Help Please!!! tjs_79ford FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 11 09-20-2009 12:30 PM
92 F-150 302 No Fuel Pressure No spark MudBugn 1987 - 1996 F150 & Larger F-Series Trucks 6 04-14-2009 02:37 PM
Tags
1977, 1981, 300, 350, 81, 84, f100, f150, flathead, ford, inline, spark, sudden, troubleshooting, turned, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
