Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 03-01-2012, 02:36 PM
Juette's Avatar
Juette Juette is offline
1959 Ford F-100
Juette is starting off with a positive reputation.
Signal lights problems
I'm sure you guys can help. I'm trying to get my signal lights to working on my (1959 f100) truck, but so far no luck. Can you guys give me any pointers on what to do or try? The headlights were an easy fix, as all was needed was a new dimmer switch, but the signal lights are proving to be more difficult.
  #2 (permalink)
Old 03-01-2012, 04:57 PM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is offline
Garage is empty, add now
theodore/teddy is starting off with a positive reputation.
Juette; I'm not sure just what is stumping you.
I will try to explain as best I can how the turn signal switch is wired. First you should have six wires attached to the signal switch two going to the front blinkers and feeding the interior indicators, then two going to the rear blinkers which are also the brake lights. then the last two wires would be power wires, one from the accessory post on your ignition switch. This one should have the flasher inline. The flasher can be found attach to the under side of the dash above and forward of the light switch, if it is where mine is. The last wire would be coming from the brake light switch on your master cylinder and feed from the A post on your light switch.
Clear as mud??
There is an outfit on Ebay that sells wiring diagrams for 20.00 or so.
Good luck
__________________
Looking for an in bed spare tire mount for styleside fridge bed.
1959 F250 4x4
Wally
  #3 (permalink)
Old 03-06-2012, 09:55 AM
Juette's Avatar
1959 Ford F-100
Thanks Teddy! The information you shared will be a big help.
Tags
1957, 1959, 2010, f100, flasher, ford, forums, light, lighting, lights, problem, problems, signal, truck, vehicle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
