View Poll Results: What does your Oil filter cap look like?
Mine is the one on the LEFT
54
93.10%
Mine is the one on the RIGHT
1.72%
Mine doesn't look like either one.
5.17%
Voters: 58. You may not vote on this poll
What does your oil cap look like?
X2 ^^^^^^^^^^^^^^
it shure would help folks out thats for shure I dont think they relize what the wrong combo does
my vote was left OEM
FWIW a Taller Cap with a Taller filter might be ok
Its just when they get on here and Read Dont use anything besides OEM Filters they change the filter to OEM but leave the Taller Cap cause they dont relize the Drain in the bottom of the housing
This Ford 6.0 is the only vehicle Iv ever Owned that you just change the Filter Element Every other Auto Iv owned you get the oil filter with the metal housing pretty hard to screw the Old School stuff up
Whats the Billet cap???? Chrome or ?????? is it the one guys use for a Pressure sensor
X2 ^^^^^^^^^^^^^^
yes Billet is made of alluminum and looks great under the hood ..I have a billet fuel filter cap and will be switching to billet on my next oil change also ...I am not 100 percent about the oil cap made by billet but the fuel cap does have an allen wrench screw in center and if i am not mistakin it can be used for a pressure reading ,...
Billet is a term describing the metal (and can be used describing materials other than aluminum, for example steel). It simply means a bar or ingot.
A part made from billet aluminium in this context, means the part was machined from a single piece of metal. It’s pretty much the most expensive way to form a part (vs forging for example).
In fact, billet aluminum can actually be an alloy.
6061 T6 billet aluminum is a high quality metal that is an alloy of aluminum, magnesium, and silicon.
An ingot is also a fancy word for a chunk isn't it? You can still call a rolled and stress relieved chunk an ingot can't you? (asking not challenging) edit - probably not looking at wikipedia ....
btw - I didn't know that the term billet also meant that it had been rolled and drawn - thanks.
Mark Im Glad that you did say something I thought that Billet was a Name brand (Manufacture)
Learned something New today
I am Surprised at the Poll thus far I thought there would be more Votes for the Wrong Cap
