Intake Air Temp sensor 2 - Ford Truck Enthusiasts Forums
Old 03-01-2012, 08:29 AM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
What problems would a high reading on this sensor cause? Sitting over-night it's showing 147* F. Having long cranking time at normal operating temps. Hoping not a HPOP problem. Running now to see what this reading changes too when warm. '07 F-350 6.0
Old 03-01-2012, 08:42 AM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
Check the wiring for a chaffing issue. Not sure exactly what that reading will cause the PCM to do with such a large difference between IAT and IAT2 as far as fueling goes on start up but you could disconnect it (PIA, I know) and make it go to a default condition to see if that aleviates the long crank time.
Old 03-01-2012, 08:51 AM
critterf1's Avatar
Maybe a chaffing problem. Also showing ECT of 181 and EOT of 225. Appears to have lots of problems. Had 15*F difference here after sitting over-night.
Old 03-01-2012, 09:09 AM
What kind of VRef voltage are you getting? Check the harness at the left fender liner also. Chaffing not usually a problem with 07's. Has the harness been butchered and have you checked the fan connector? Any aftermarket modifications?
89 f250 7.5l 460 Coolant Temp Gauge Problem Anthony Bauwens 1987 - 1996 F150 & Larger F-Series Trucks 2 11-08-2016 09:39 AM
'69 fuel and temp gauge problems gbass82 1967 - 1972 F-100 & Larger F-Series Trucks 26 09-16-2016 07:21 PM
Ambient Temp Sensor eagle327 Electrical Systems/Wiring 6 10-17-2015 08:51 AM
Infrared Thermometer Macs1964F100 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 06-05-2014 10:18 AM
V10 Coolant Temperature Sensor Location? suprdutyv10 1999 to 2016 Super Duty 0 02-20-2010 10:30 PM
Tags
2001, 60, 60l, 73l, 86, air, code, diesel, f150, f250, ford, intake, sensor, temp, temperature
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
