Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > International Region > Australia Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
  #1 (permalink)
Old 03-01-2012, 05:26 AM
SSSimon SSSimon is offline
2005 Ford F-250
SSSimon is gaining momentum as a positive member of FTE.SSSimon is gaining momentum as a positive member of FTE.
HVAC stuck on demist
On the w/e I had the problem that the demister was stuck on no matter where I positioned the selector switch.
I popped the bonnet and pulled the airline off the top of the airpump. The pump detected the pressure drop and started pumping. I stuck my finger over the air hole and the pump built up the air pressure then stopped.
I then reattached the airline and checked the HVAC. All the setting seemed to be working. It was like I somehow unjammed the demister setting by removing the airline.
One for the memory bank for next time it happens. Anyone else encountered this problem? If so, how was it fixed?
__________________
Mods done: lots of cheap mods (Hutch, IC boots, plenum inserts, IH uppies, HPx, AIH delete, EBPV delete, hi flow outlet, CCV mod, OCR, Superchips, Zoodad, 6637, 4" TB exhaust, JW valvebody, coolant filter, FRx, '05 HD lights with switch bypass relays, B100 ready fuel system)
Mods NOT done: big oil, big brakes, big turbo
Next mods: ? tuner, G2WW (on the shelf), alloy diff covers
Australia: where Mechanics use spanners and Plumbers use wrenches...
  #2 (permalink)
Old 03-01-2012, 06:55 PM
BPofMD's Avatar
BPofMD BPofMD is online now
Old-Timer
2005 Ford F-250
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
Most any vacuum leak will default the HVAC to defrost. It's a safety thing. If you have Electronic select 4 wheel drive you may have a leak in the lines going to the wheels. This is usually the case with this complaint. Can you go into 4 wheel drive?
__________________
BPofMD - Bud - USN-Actively Retired
Maryland Chapter Plankowner
2005 F250 PSD 4X4 LB Crew-cab Arizona Beige / Blue Spring / Gauges / Coolant Filter / SG-II / Peragon Bed Cover/ P/S Filter/ MAG-HYTEC differential cover/
2007 Arctic Fox 30' Fifth Wheel -2012 VW Passat SE TDI (An ALL-DIESEL family)
Join the Maryland Chapter click HERE
  #3 (permalink)
Old 03-02-2012, 03:44 AM
2005 Ford F-250
I used 4WD high and low a couple of months ago. I'll check again next time I get the truck out. Does the pump time-out if it runs too long?
__________________
  #4 (permalink)
Old 04-11-2012, 06:04 PM
Jterr Jterr is offline
Garage is empty, add now
Jterr is starting off with a positive reputation.
Where is the airpump in a 2002 F-150?
  #5 (permalink)
Old 04-12-2012, 06:35 AM
2005 Ford F-250
No idea on the F150. You should be able to locate it by the buzzing sound it makes when you turn the ignition on. It buzzes while it builds up pressure, then switches of. Open the bonnet then turn the key on and find the noise!
I re-greased the front hubs with tons of help from Chunder at the F250 GTG the other w/e.
We had the front wheels jacked up and checked the engagement of 4WD once the hubs were done. All worked well.
I was surprised that even with the front wheels in the air, to get the hubs to disengage the wheels had to be turned backward.
Note to self: When coming out of 4WD stop and back up for about 5m to let the hubs disengage.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
