Header questions
I'm guessing you have a 5.0 or 5.8. I'd say if you get good quality gaskets, you probably won't have much if any issues with them. Most of the gaskets that come with headers are the poor quality paper type. Those don't last. I like Percy's Seal 4 Good gaskets.
Alot of guys like the Summit brand shorties, which are reboxed Pacesetter brand. If you get headers make sure the flanges are 3/8 and not 1/4 inch.
on
I think the biggest problem with headers is with the bolts working loose, that always leads to a blown gasket. I have had both good and bad luck with headers gaskets, the original set I installed with the headers on my truck now never sealed right and for some reason the bolts were always working lose, but after replacing them last summer with Felpros it's been perfect.. no signs of leaks or loose bolts since.
not to mention make it louder and sound godly awesome, long as you can get good thick gaskets, one guy i knew used 2 gaskets over each other and tightened the crap outa his bolts then put another bolt behind that one to keep it on, ran great never had issues with it, but then again he was running a 500hp mud truck..
FE352
15
03-18-2007 11:46 PM
