C6 ---> E4OD (Swap Questions) - Page 2 - Ford Truck Enthusiasts Forums
Old 03-08-2012, 01:58 PM
David85's Avatar
David85 David85 is offline
David85 has a good reputation on FTE.David85 has a good reputation on FTE.
Quote:
Originally Posted by fiftyfordfloored View Post
That explains it, my truck has the automatic speed control. I always thought that was a fairly rare option on the 80's Diesels.
I picked up my setup today. '93 7.3L with the E4OD and t-case, which I probably won't be using as my original one is fine. Actually got the front half of the frame with it as well, cross-member and all. Also the front drive shaft came with the deal, but, the truck it came out of had a Dana 60 (F350) and I have a Dana 50 TTB due to mine being an F250HD. The fluid in the trans looked perfect, and the drivetrain had 87k miles on it. It was parted do to it being used as a plow truck (frame rust), however, there was an aftermarket transmission cooler on it. I think I'm going to take my chances and just drop it in. I can always pull it back out.
I'll be using the Baumann unit.
I appreciate your input; nice to hear from someone that's done the conversion.
Anytime. It'll be cool to see someone else with the same setup
I believe the newer transfer case is rated for more torque and has a lower crawler range.
If you aren't going to rebuild the transmission, I would at least drop the pan to see what it looks like before putting it in.
Old 03-08-2012, 03:08 PM
fiftyfordfloored's Avatar
fiftyfordfloored fiftyfordfloored is offline
fiftyfordfloored is gaining momentum as a positive member of FTE.
I'm definitely going to service the transmission and check it over first.
The transfer-case that's in my truck is going to have to stay, as I need the speedometer cable and and the speed sensor to run the transmission controller. It's always babied off-road, and the majority of the time I use 4x4 is in the winter to get out or my driveway (which is basically a long dirt farm road).
I'm going to have to build linkages. The guy busted the heck out of the transfer-case linkage and ruined the shifter pulling the cab off the truck. David85, how much did you have to modify your transmission shift linkage to get it to work right?
Old 03-08-2012, 04:46 PM
David85's Avatar
D-Oh! - I knew that
The rod that connects to the arm on the side of the transmission - it has to be lengthened. However that only applies to 89-91 trucks. 92 and later use a cable shifter and eliminate the bell crank lever system entirely.
You can keep all your C6 related shift linkage except for that one last rod that connects to the shifter arm.
However, since you're dealing with a 92 and up version of E4OD, the lever on the side of the transmission won't be the correct type. It can be swapped.
This is the style you need (note how similar the style is to the C6):
This is the style the 1993 model year will have (note how the lever points up instead of down):
Old 07-03-2014, 11:44 AM
Brian Piper Brian Piper is offline
Brian Piper is starting off with a positive reputation.
I've got a question and I'm hoping someone here will know. A mechanic told me the valve body for E4od would fit a C6 and using the right torque converter it would give a 4th gear. Any truth to this?
Old 07-03-2014, 11:56 AM
Red454sedgwick Red454sedgwick is offline
Red454sedgwick is starting off with a positive reputation.
No, a few of the guts can be changed, but I think your mechanic confused ford with GM you can change a 350 trans to a lock up converter that would add a what some would consider another gear.
E4OD to M5OD swap Zgarriott1 1978 - 1996 Big Bronco 11 11-29-2016 10:38 PM
1993 F350 IDI 4x4 E4OD to ZF5 swap JeffStrachan Clutch, Transmission, Differential, Axle & Transfer Case 2 09-05-2016 01:06 AM
C6 to e4od swap Blind Driver 1987 - 1996 F150 & Larger F-Series Trucks 1 02-29-2016 12:43 PM
C6 Conversion Update & Filler Tube Questions Ford Tempo Fan 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 07-30-2015 07:33 PM
2wd to 4wd conversion 300bigsix 1987 - 1996 F150 & Larger F-Series Trucks 6 10-09-2014 01:39 PM
Tags
1986, 1993, 69, 73l, 87, automatic, c6, cg, control, diesel, e4od, f250, idi, module, mpg, swap, transmission, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
