IWE Vaccum Line-need help
Old 02-29-2012, 12:51 PM
krys4990's Avatar
krys4990
krys4990 is offline
I need to replace the IWE vacuum line that connects to my front, driver side wheel (2004, FX4, SCREW). If I call the dealer, they want a bunch of money, so I would like to try to save a few bucks by getting it online.
If I use my VIN & lookup the part online via (FordParts.com), I get the number: 3A788, description: locking hub vacuum tube, and the price is about $15. However, there is nothing showing where or what that part is. From the diagram, it appears that the part number I need is 3A785, which is $75.
Does anyone know what the correct part number is, or how to tell? Or is there an aftermarket part/brand that anyone would recommend? My truck has a 2" leveling kit, so getting longer lines would probably help prevent the lines from coming undone at the wheel hub.
Old 02-29-2012, 02:30 PM
60DRB's Avatar
60DRB
60DRB is offline
You can just use generic vacuum line from any auto parts place, as long as the inside diameter is the same. You can cut the length to fit your lift application and tape or bundle tie the vacuum and vent lines together to route them in a similar fashion to stock.
jgdds
1999 to 2016 Super Duty
01-21-2016 05:44 PM
Dschonauer
1997-2006 Expedition & Navigator
03-11-2015 09:53 AM
C-AREVALO
02-12-2014 10:05 AM
tite4x4
1978 - 1996 Big Bronco
04-26-2004 11:08 AM
Quick Reply: IWE Vaccum Line-need help
