Thru Frame Brake Plumbing
Has anyone used these items from Speedway or others. I am in the process of plumbing the front disc brakes and while I am leaning towards welding the tabs on the bottom of the frame for the flex lines and connecing the hard lines from the proportioning valve to those. I am also considering the thru frame hardware to make it all a little cleaner and better looking.
Or is there another system I am unaware of?
Thanks,
Thanks,
Thanks,
Thanks,
Sam
Yep, I use them too. Pretty slick way to go from NPT to AN if you need the conversion. I run hard line up to the feedthru and then braided stainless from there to the caliper. BTW, I don't ever go to Nowhere AZ...not that I would ever be worried about a piece of stainless tubing breaking if I did. In fact I would hope that it "brakes".
They look a lot like the ones I use from inline tube that are 30.00 a pair
Inline tube The brake plumbing experts
Like my grammar skills? ;-)
Sam
and it can't come out the back, too far away.. so, I had to go over and around the MII on the inside of the box, and then thru..
My pics
in the enderwell
on the inside of the chassis
over the MII
Sam
