Ford L8000 PARTS??? - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Ford L8000 PARTS???
Old 02-28-2012, 10:39 PM
1985L8000cat3208 1985L8000cat3208 is offline
1985L8000cat3208 is starting off with a positive reputation.
Question Ford L8000 PARTS???
Does anyone know where or is a good source for Ford L8000 parts???
Cheers,
Brock Joubarne
Iroquois, ON
Old 02-29-2012, 08:02 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
There's not going to be one source, but dozens, because most of the parts are obsolete. It all depends on what you're looking for....which is?
The 1980/89 Ford HEAVY Truck Parts Catalog is available on a CD from hipoparts.com.
Old 02-29-2012, 11:36 AM
Looking for Body Parts for a 1985 L8000!
Cheers,
Brock Joubarne
Old 03-04-2012, 06:09 AM
You have to be more specific than just saying body parts, there are 100's of them!
I have to look up each part number individually, then type it into the Ford Dealer website to see if it's available...or not.
If available, will list the part number, MSRP and FTE member discount prices. If obsolete, type the part number into two website to see if anyone has any.
If found, I'll list the part number, sources/phone numbers. And this rigamarole is just for ONE part number!
The same process has to be repeated over and over again for each part number. This takes time, so I need to know exactly what parts you need.
The alternative is...going to a dealer and I know what they'll say the second you mention the year: Obsolete! Whether the part is...or not, because...
Most partspeeps in today's world don't wanna mess with older vehicle, so they just "shine you on!"
Old 03-07-2012, 03:12 AM
rummur s.c.'s Avatar
rummur s.c. rummur s.c. is offline
rummur s.c. is gaining momentum as a positive member of FTE.
If you're on the west coast I have a couple cabs that are being parted out.. What parts are you after?
Old 03-08-2012, 04:16 PM
I am based here in Iroquois, ON, Canada... Just looking for doors and quarter fenders, grill and last but not least cab corners!
However, the truck is in really good shape but the cab does need some work!
Thanks for all the help!
Cheers,
Brock Joubarne
Old 03-10-2012, 01:55 AM
Those trucks were really popular over there on the east coast, should be pretty easy to find parts trucks, or just parts..
Old 02-14-2013, 11:56 AM
beetle55 beetle55 is offline
beetle55 is starting off with a positive reputation.
Question L8000 parts
I'm looking for new rubber seals for around the doors for my 1984 L8000. Would also like to replace the floor mat & right dash board. Anyone know a place where I can find these parts. Thanks B.Bailey
Old 02-18-2013, 02:35 PM
Quote:
"Quarter" fenders is another name for pickup bed panels. No L8000 is a pickup.
All 500 series and larger trucks are sold as Cab & Chassis. Any type of "back of cab" equipment is supplied by the body maker.
Old 02-23-2013, 12:57 AM
devlenf devlenf is offline
devlenf is starting off with a positive reputation.
f 8000 drum studs?
Hello,
I believe number dummy is the person i need to ask but whoever can help, please help. I have a 1990 F8000 and a 1993 F9000 and find it very hard to find parts. I have people working on them at a garage but they are having trouble as well so I may not get the part names exact but will do my best. I first need for the f8000 drum studs and nuts. I guess the drums have studs that hold them on and they are "turning or spinning" in the holes and he cant get them out to replace the drums and brakes. these are the front tires. I need them for both front tires. The drivers seat also continually leaks air so I need the air cushion I guess to replace. Thats the most important. My email is devlenf@gmail, please help asap. I have been broken down for q month now. These trucks were truned into septic trucks so they have vacuum pumps on them if anyone out there knows anything about vacuum pumps I dont and I cant find anyone around here(chattanooga, Tn) to work on them.Thanks
devlen
Old 02-23-2013, 12:58 AM
f8000
here is the last 8 of vin if that helps
LVA35661
Old 02-23-2013, 10:48 AM
Quote:
A35661
The last 6 digits of the VIN is the trucks specific serial number.
Looking up parts for these BIG trucks is a real b!tch, because there are so many different combinations.
Suggest you contact FTE sponsor Tousley Ford in White Bear Lake MN for assistance (tousleyfordparts.com).
I'd like to help, but I don't know anything about these trucks. We never saw any, never worked on them in West LA
Old 03-01-2013, 09:58 PM
Thanks for the help I will call him. yea it has been a real pain trying to find parts.
Devlen
Old 03-27-2013, 12:10 AM
devlen, you should really consider taking your truck to another shop. The front axle is the same or atleast very similar to every other heavy trucks front axle. So, if your guy is having trouble with them he must be very new at this.. The wheel studs may be stripped out of the hub? Either way your guy should know how to cut the nuts off and pound the old studs out of the hub.
All these parts should be relatively easy to find at any big truck shop/ warehouse.
Old 04-07-2013, 06:25 PM
Thanks Rummur,
I did take it to another shop and they said it was bolts and not studs, so they cut some off and replaced them so we got it done,
Thanks
L 8000 tmolloy Large Truck 2 04-15-2016 01:11 PM
1978 l8000 D W driller Large Truck 0 08-08-2014 10:38 PM
L8000 Parts Help DJones1234 New Member Introductions 2 10-15-2013 08:00 PM
1987 Ford L8000 Turbo downpipe exhaust gemtwist Large Truck 2 03-17-2012 12:44 PM
1985 Ford L8000 PARTS??? 1985L8000cat3208 Large Truck 5 12-08-2011 11:34 PM
Tags
1994, 8000, catalog, craigslist, door, fender, ford, heavy, l8000, number, online, parts, quarter, truck, vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
