Gear Vendors? - Ford Truck Enthusiasts Forums
Gear Vendors?
Old 02-28-2012, 09:18 PM
acprimus631C acprimus631C is offline
acprimus631C is starting off with a positive reputation.
Gear Vendors?
I've seen mention of it around here. Is it all mechanical or does it have any electronics in it? How much would it cost for a C6?
Old 02-28-2012, 09:39 PM
bashby's Avatar
bashby bashby is offline
bashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to all
It is electronically controlled. Search on ebay, there is usually something there... there was a guy selling rebuilt ones a while back.
Old 02-28-2012, 09:44 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
^^^ x2
And new, I think they're around 2k $.
Old 02-28-2012, 10:16 PM
Aww man, I don't like electronics and that's quite a ways out of my budget. Guess I won't be looking into that. Thanks guys.
Old 02-28-2012, 10:20 PM
Used i'm sure you can ****** one for under a grand.
Old 02-28-2012, 10:33 PM
joshofalltrades joshofalltrades is offline
joshofalltrades has a good reputation on FTE.joshofalltrades has a good reputation on FTE.
to say that its electronic is not necessarily true. from what i've read about them, an electric solenoid controls a hydraulic valve that actually shifts it in and out, and it can be set up to be shifted either manually or automatically. for manual shifting, there would be absolutely no need for electronics, just a simple switch near the shifter or steering wheel, or a foot switch. for automatic shifting, i haven't looked into it much, but it probably uses a fairly simple controller
Old 02-28-2012, 11:34 PM
just looked on fleabay, the cheapest one there right now is 1100, craigslist has nothing in seattle.
Old 02-29-2012, 08:50 AM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
you can run them with a simple toggle switch if you so desire. The controller went out on the one we have, and just switched it manually all the time. They are self contained, but typically mount on the output of the transmission.
Old 02-29-2012, 11:53 AM
1986Beast's Avatar
1986Beast 1986Beast is offline
1986Beast is starting off with a positive reputation.
What is your opinion on them? I was also considering buying one of these for my rig. I usually drive about 250+ miles a week and would consider running more if the truck got better than 14-16 mpg. Also I don't really care about going faster I usually cruise at 70, but I would like to drop the RPM as the motor sounds like she is wound pretty tight.
Old 02-29-2012, 12:07 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
the problem with the old C6 is not just a lack of over drive.it also lacks a clutch to lock the engine to trans directly.
a GV doesn't correct this issue.your still wasting too much fuel heating trans fluid instead of forward motion.
for the price,you could find a used E40D,and buy an aftermarket (easy to wire up,use,customize.) and be much further ahead.then you get 4wd whenever you need,od whenever you need,a locking connection,and a coast clutch.thats if you wanted to keep an auto.you might save $ buying a zf5 with a decent clutch.probably close to,if not more if you need a new clutch though.
they would work fine behind a 4sp,but again,it would just be cheaper to do the zf5 swap.
imho,they are over priced,or better built to put behind a truck that you put real towing gears in,already have the OD trans,and want to get your economy back.
example; putting one behind the zf5/e40d f-super duty trucks with their low gearing.now that would be worth buying one for 1k-1500.you'd have it all.low end grunt to tow a train,and reasonable cruising rpms for economy.
i would not buy one to put behind the C6.it only cures some of the problem for about the same money as an OD trans.or the same $ if buying new (if not more.)
Old 02-29-2012, 08:58 PM
86f250XLT-4x4's Avatar
86f250XLT-4x4 86f250XLT-4x4 is offline
86f250XLT-4x4 is starting off with a positive reputation.
do they make a gear vendor for the t19?
Old 02-29-2012, 08:59 PM
They make one for every Ford tranny.
Old 02-29-2012, 09:20 PM
fellro86's Avatar
You can get standalone divorced style as well.
Old 03-02-2012, 11:29 AM
Thanks y'all for the opinions. If I can find one cheap and get a manual switch for it, I might go with that. I'm trying to avoid electronics on this truck as much as possible. Not that I have anything against them, or an E4OD in good shape, I just don't want the hassle of having something break that I can't fix as I'm no electrical or tranny expert.
Old 03-02-2012, 06:14 PM
turtlemann14's Avatar
turtlemann14 turtlemann14 is offline
turtlemann14 is starting off with a positive reputation.
amen lol
i understand where this guy is coming from
Kar-puter...aka Win 8.1 tablet in Excursion ExPACamper 1999 - 2003 7.3L Power Stroke Diesel 39 05-14-2015 04:43 PM
Transmission rebuild! pjcat Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 04-06-2015 05:58 AM
Power Brake Upgrade for 66 F250 AubreyA3 1961 - 1966 F-100 & Larger F-Series Trucks 6 01-30-2015 11:39 AM
Rear audio controls crap - '03 Expy OneLong4x4 Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 0 07-08-2014 12:41 PM
Transmission wire harness HELP! charon61285 1999 to 2016 Super Duty 0 04-10-2014 02:21 PM
Tags
1977, 1999, 355, 73, 73l, automatic, diesel, f150, f250, f350, ford, gear, gears, mpg, vender, vendors
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
