85 F-250 gas pedal does not return. - Ford Truck Enthusiasts Forums
Old 02-28-2012, 06:56 PM
SpecialFX99 SpecialFX99 is offline
SpecialFX99 is starting off with a positive reputation.
I have an 85 F250 with the 460 that I am trying to get rid of. It's been sitting for a good while, maybe as long as 2 years. I went to start it today to check things out before a potential buyer looks at it tomorrow and found that when I pressed the gas pedal to give some gas to start, the pedal stayed depressed and did not return. The throttle cable is attached, but has a lot of slack and it not returning the pedal. I tried to find the other end of the cable in the engine bay, expecting it to have become disconnected for something, but I was unable to tell what was what around the carb.
Can anyone tell me what might be causing the issue and where exactly to look? This will be my first time wrenching on this truck so I am not at all familiar with it. Thanks!
Old 02-28-2012, 07:04 PM
Franklin2's Avatar
Franklin2 Franklin2 is online now
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
The throttle is hooked on the driver's side of the carb. You will have to take the aircleaner off to see it. Knock $300 off it and let him worry about it.
Old 02-28-2012, 07:05 PM
Will it be fairly obvious with the air cleaner off? This is the first I've messed with anything carbed
Old 02-28-2012, 07:19 PM
82f100460's Avatar
82f100460 82f100460 is offline
82f100460 is gaining momentum as a positive member of FTE.82f100460 is gaining momentum as a positive member of FTE.
here's a picture of my 460 in it's original state, although they're all pretty much the same...look right in the middle of the pic on the side of carb. You will see the linkage on the side of the carb, the return spring and then the cable (black) going back to the firewall. This was an original throttle cable so yours should look similar.
disconnect the cable fromt he carb and see if it frees up. If it does...then it's your carb sticking. If it is still stuck, then it's the cable / spring.
Old 02-28-2012, 07:20 PM
Franklin2's Avatar
Once you see the throttle cable, you can disconnect it from the carb by prying on it. There is a little metal ball made onto the carb, and there is a socket on the throttle piece. It just snaps on. Then you can figure out if it's the cable, or the carb itself. If you get it freed up, a little wd40 would probably do wonders for it.
Old 02-28-2012, 07:25 PM
Thank you guys. I'll have to wait until tomorrow because it's dark out now. Is there anything specific I need to know about getting the air cleaner off? I need to try and sort it out on my lunch break tomorrow so I won't have a lot of "figure it out as I go" time, lol
Old 02-29-2012, 08:40 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
E1TZ-9A758-E .. Accelerator Cable-19 3/4" long / Obsolete
Applications: 1981/85 F100/350 & Bronco 255/302/351W2V/460 // 1982/83 F100 3.8L V6.
NOS PARTS SOURCE in Olathe KS has ONE = 913-220-5746.
No Ford Dealer, no other obsolete parts vendor has any.
Old 02-29-2012, 10:45 AM
85lebaront2's Avatar
85lebaront2 85lebaront2 is offline
Old School Hot Rodder
85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold
I have a good used one from my 86 if you need it. Here's a view of the 86 setup.
Old 02-29-2012, 07:07 PM
Turns out it was just gummed up. A little PB blaster and working it open and closed for a bit and it works fine.
...But now the truck won't start. Brand new battery. Pretty sure starter is turning the engine, tried both tanks. Acted like it wanted to start with starting fluid but didn't quite make it. I'm thinking it's not getting fuel or the fuel is no good. Any suggestions?
BTW, this has been a very helpful forum so far!
Old 02-29-2012, 10:21 PM
The Masked Rider The Masked Rider is offline
The Masked Rider is gaining momentum as a positive member of FTE.
(with the motor OFF) remove the air cleaner, use a flash iight and look down into the carb and throttle it a couple times. If your getting fuel, you will see it being shot down into the carb. If not, check the filter.
Old 02-29-2012, 10:25 PM
82f100460's Avatar
If it's been sitting for a couple years like you say...good chance the fuel is not real good.
if you've cranked it for a while, that should have been plenty of time for the pump to get fuel up to the carb. look down the troat of the carb and stroke the linkage on the carb....you should see 2 good solid stream of fuel being pumped down the throats of the primaries (2 most forward barrels). That will tell you if you're getting fuel.
Old 03-01-2012, 01:41 PM
I tried this and it's definitely not getting fuel. I'm going to try a fuel filter and new gas.
Is the information I found online correct that the fuel filter is on the frame rail under the cab on the driver's side? I also saw one place that said I need fuel line quick disconnect fittings to change it? I've only ever change a fuel filter once before (73 coupe deville) but it didn't require any special tool o fittings.
Old 03-01-2012, 09:32 PM
The fuel filter on a carbureted 460 is at the carburetor inlet. There are two different fuel supply systems on these trucks with or without the hot fuel handling package. The easiest way to tell is to look at the driver's side of the timing cover. If you have the hot fuel handling package all that will be there are two steel tubes, a 5/16" and a 1/4". If you do not, then there will be a mechanical fuel pump there.
If you have the hot fuel handling package, there are two low pressure in-tank electric pumps. There will be a small blue fusible link at the starter relay, if you jump that to 12 volts the selected tank pump should run and deliver fuel to the carb, be warned, Holley carbs do not like sitting and drying out, if you get gas to it, it will most likely leak like a sieve.
Old 03-01-2012, 09:49 PM
Any pictures? I'm not sure if I am following you or not. I definitely do not see a blue relay on the starter solenoid though.
Old 03-01-2012, 10:20 PM
It's not a blue relay, it's a blue fusible link that slips over a small terminal on the starter relay.
Parking Brake Pedal Return Spring? kr98664 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 11-12-2016 10:04 PM
Parking brake pedal/assembly question (not the rotors/shoes) Sous 1999 - 2003 7.3L Power Stroke Diesel 5 01-18-2016 12:10 PM
65 F100 Throttle/Pedal Sticky jlintvet 1961 - 1966 F-100 & Larger F-Series Trucks 7 12-28-2015 08:37 PM
Gas pedal cable disconnected on 95 f250 w/5.8l Andy's Beast 1987 - 1996 F150 & Larger F-Series Trucks 2 09-15-2013 11:48 PM
1977 F250 Clutch Pedal sporttaz 1973 - 1979 F-100 & Larger F-Series Trucks 7 10-25-2011 10:07 PM
Tags
460, 78, 80s, change, club, f250, ford, fuel, gas, kentucky, pedal, ranger, replace, responding, sale, truck, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
