Dear Diary . . .
#31
So one of the concerns I have is that my C6 does not have an over drive and i will not be able to cruse the interstate easy, so what would be nice is a 2 speed rear end. In my search to find said rear end i found a complete Dana 60 disc brake rear end out of a early 70 chrysler imperial with 3.23 gears for $150, i'm going to look at it on monday so . . .
#32
UPDATE TIME ! ! ! ! ! !
So this is a big update, not only content wise but the information contained is a turning point.
So the thorn in my side from this truck is the mess the PO created by putting power steering, from a mustang i think, in it.
This hole is a calculated cut for the pit man arm to reach through. So now i start cutting and grinding to clean up the frame, and what do i find . . .
Yes that is a crack, it's just to the left of the hole in the previous pic. So my first question is, can i just cut out the crack and weld it up?
And then with this new development I'm going to box in at least the front of the frame, so my next question is how do box the frame and still keep the Master cylinder in the stock location?
Well, that's all for now.
#39
Their is more than one way to skin a cat, it even differs by geographical location.
So after reading countless ways on countless pages and forums on ways to sand and paint a frame i think i have a process that might could work. I have burnt several flap disc's, picked wire from my legs and arms from wire wheels, and salvaged enough blast media from my paints to do my front axle. I'm finally on the home stretch for finishing my frame.
Tomorrow's check list is: wash & dry, wash & dry, and apply rust inhibitor.
Oh . . . . so my paint process is, I think . . . .
1. Rustoleum rust reformer
2. Rustoleum Primer
3. Paint (?)
2. Rustoleum Primer
3. Paint (?)
#42
300 I6 install info
Front Cross member:
Trans-Dapt Performance Engine Swap Motor Mounts 4037 - SummitRacing.com
with using 70's style mounts
Ignition
https://www.ford-trucks.com/forums/1...-shopping.html
Duraspark_distributor_recurve_instructions_index
other
https://www.ford-trucks.com/forums/1...t-the-efi.html
Front Cross member:
Ignition
other
#44
#45
I have to agree. IF you could be assured that you had solid full-penetration welds all around the patch, with no discontinuities, and you were able to stress relieve the welded metal, you "might" be OK. That is a very highly stressed area of the frame, known for cracking around the steering box holes. With the steering box there, you can't fish-plate or box the frame.
