2000 F-350 7.3L Diesel Fuel Pump Location? - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 02-28-2012, 03:26 PM
andrewjdouglas andrewjdouglas is offline
andrewjdouglas is starting off with a positive reputation.
Can someone tell me where the fuel pump is located on a 2000 F-350 7.3L Diesel? Also, how complex is replacing this?
Thanks.
Old 02-28-2012, 03:52 PM
Kajtek1's Avatar
Kajtek1 Kajtek1 is offline
Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.
The electric priming pump is attached to the rail under the cabin. Easy to spot.
Old 02-28-2012, 04:24 PM
Are the "priming pump" and the main fuel pump one in the same? Dealer wants almost $1000 to replace, saw the electric pump online for $150. Trying to figure out if I want to take on the repair. Thanks.
Old 02-28-2012, 07:18 PM
Kajtek1's Avatar
Those engines also have HPOP what pumps high pressure oil to injectors. Those are expensive.
Go to 7.3l section for more details. Start with checking what dealers estimate says.
Charging $1000 for replacing $150 part would be unusual, but not uncommon.
Old 02-28-2012, 08:55 PM
F350-6's Avatar
F350-6 F350-6 is online now
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
The fuel pump is located on the frame rail under the driver seat. You need a fuel line disconnect tool to remove the lines, the same way you do on a gasoline fuel filter. Then there are 2 small nuts holding 2 wires on the pump. It's not hard to change, you just end up with diesel fuel on you.
Are you sure they are quoting you that much money for just changing the fuel pump? If it's the HPOP (high pressure oil pump) that might be different. Still way overpriced for what you can do it yourself for, but at least different.
And yes, there is only one pump on this engine that pumps fuel from the tank to the motor and it can be purchased for $150 or less at many parts stores.
Old 02-28-2012, 10:10 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to the 1999 - 2003 7.3L Power Stroke Diesel forum.
Old 02-28-2012, 10:51 PM
It's a Ford dealer, they want $550 for the fuel pump and $75 for the fuel filter. Labor is $125 diagnostic and another $150 to install. I bought all and an airf ilter online for $170. Going to give replacement a shot, can't be worse than the 99' Saab 9-5 that I replaced the fuel pump in last weekend. Not a good run for me and fuel pumps... Any pointers are appreciated. Thanks.
Old 02-28-2012, 11:10 PM
snakedoc's Avatar
snakedoc snakedoc is offline
Ford With Out Tax Money
snakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to behold
it is easy , it is on the rail take lines off wire off put the new one on the let the pump run with the key of 30 sec then key off then on 30 sec do that 5 time and you should be good. that will prime the pump and lines.
Old 02-28-2012, 11:11 PM
Backdraft-14's Avatar
Backdraft-14 Backdraft-14 is offline
Backdraft-14 is gaining momentum as a positive member of FTE.
I had to purchase the plastic fuel disconnect tool and cut the two halves apart because my metal disconnect tool couldn't fit. This was about 3 years ago for me. (2001 F-250 Crew cab) other than that it was fairly simple and straight forward.
This is a good picture of what you will be looking for.
Good luck.
http://www.ford-trucks.com/forums/11...pump-help.html
Old 03-01-2012, 03:38 PM
DavidE DavidE is offline
DavidE is starting off with a positive reputation.
Fueli line disconnect tool
Back draft where did you get the plastic fuel line disconnect tool, what did it look like and and what was the size/part # etc pls? Thanks
Old 03-01-2012, 03:42 PM
timmyboy76's Avatar
timmyboy76 timmyboy76 is online now
timmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to behold
Harbor Freight
Old 03-02-2012, 08:47 AM
Fuel line disconnect tools
Thanks Timmyboy. If you buy the last two you list do you need the first one listed? Do they come with instructions? If not where do you find those pls?
Old 03-02-2012, 11:50 AM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
FYI - The fitting on the rear of pump inlet is not the same as the front. It is a differet type of quick connect.
Old 03-02-2012, 01:07 PM
Fuel line disconnects
Thanks Payson. Do you or anyone else have something similar for the other type of connector you say is there pls? Do I really need all the types of tools Timmyboy showed? Appreciate the help a lot!
Old 03-02-2012, 01:40 PM
PaysonPSD's Avatar
Quote:
This works perfect for the quick-connect at outlet side of pump.
Fuel Filter TennesseeRV 1999 - 2003 7.3L Power Stroke Diesel 41 01-04-2013 09:01 PM
2000 F350 7.3 L diesel fuel pump issue stewart2000 1999 to 2016 Super Duty 2 07-26-2012 12:42 AM
fuel pump 7.3 pwerstroke steeltaber General Diesel Discussion 2 06-10-2011 09:03 PM
powerstroke fuel pump steeltaber 1987 - 1996 F150 & Larger F-Series Trucks 4 04-10-2011 09:33 PM
Best programmer? Smurff350 1999 to 2016 Super Duty 1 11-30-2010 10:41 PM
Tags
2000, 2001, 2007, 73, 73l, diesel, f250, f350, ford, frame, fuel, fuse, location, pump, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
