Best aftermarket hitch for E-350?
I'd like to add a step at the back of my E-350 to make it a bit easier getting in and out since it's so high. Thought I'd install a trailer hitch and use that to mount a step plate I'd have welded up. Then I'd still have the hitch should I ever need to use it.
Any thoughts on which after market trailer hitch is easiest to install or works the best?
Thanks!
Thanks!
the step bumper seems to be a less common option, but i have one and i love it. my local junkyard only gets a few of them a year, but plenty of the smooth chrome ones that fit as close as possible to the body.
if you choose to add a hitch reciever, they're all about the same within any given weight rating. again, a junkyard will likely have several, or any company that thinks about towing (uhell, jc whitney, your local RV supply, etc) will have options.
Thanks!
Thanks!
For the trailer hitch, suggest that you get the heaviest duty that aligns with your vans towing capacity. Who knows down the road what you might want to tow, or, what a perspective buyer of your van will want to tow. Good luck, Mike
nikmish
06-03-2014 08:30 PM
