60's Ford Truck VIN Decode Help Please?
<HR style="BACKGROUND-COLOR: #d1d1e1; COLOR: #d1d1e1" SIZE=1 itxtNodeId="1655"> <!-- / icon and title --><!-- message -->
Hi! I recently bought a Ford Pickup, definitely a project, & I can only locate 1 vin plate on the driver's side door. Can anyone help me decode, please? MVD here in AZ is absolutely no help, & I have no title. It's F10BR567080.
Any help would be really appreciated. I've googled online but get mixed/conflicting information. Thank you!
There is also a VIN on right frame rail. Send me a PM re: Title.
Where in AZ are you located?
I recently bought a Ford Pickup, definitely a project, & I can only locate the VIN on the Warranty plate on the driver's side door.
F10BR567080
F10BR567080
The only places the VIN will be found are on the Warranty Plate and stamped (hidden) atop the right (passenger) side frame rail either just in front of, or partially under the cab.
F10 = F100 2WD
B = 262 1V I-6.
R = San Jose CA Assembly Plant.
567080 = 1964, assembled July 1964.
Vin DeCode Help
Thank you everyone for all the info. I suspect the door (with plate) was a replacement of the original. Comparing photos of the front end & grille & the truck having a Twin I-beam suspension, appears to be a 1966 with a 1964 driver's door. Will have to find the vin on the frame rail to be sure. Will repost when I get to that. May be a while. Thanks again. Great forum.
Peeps replaced damaged left doors with used doors. 99.9% of the time, they did not install the original Warranty Plate on the replaced door.
When this occurres, the VIN, all the codes on the Warranty Plate no longer match.
I was wondering if someone could help me decode my warranty plate?
Warranty Number: F10JN422624 // W.B. 114 / Color: I / Model: F100 / Body: 66B / Trans: A / Axle: 12 / MAX GVW LBS: 5000 / Cert. Net HP: 114 / RPM: 3600 / DSO: 23
Body code rearranged as to the sequence it appears on the Warranty Plate. You omitted the MAX GVW LBS
F10 = F100 2WD
J = 223 1V I-6.
N = Norfolk VA Assembly Plant.
422624 = 1963, assembled June 1963.
114" Wheelbase.
I = No such COLOR code.*
F100 2WD, 5,000 GVWR
66B = Uni Custom Cab.
A = Ford type 3.03 3 Speed Manual all Syncromesh Transmission.
12 = Ford 9" Rear Axle / 3.89-1 / No Limited Slip / 3,300 lbs. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
114 net HP @ 3,600 RPM
23 = Philadelphia PA Ford District Sales Office, where the original selling dealer ordered the truck from.
* The COLOR code cannot be an I / It might be an L = Holly Green or a T = Sandshell Beige. If neither, take a close look and post what it actually is.
Or a previous owner liked the looks of the 1964 grille better.
1961-1964's have the parking lamps within the grille, 1965/66's have the parking lamps mounted above in the upper grille panel.
Left: 1964/66 / Right: 1961/63.
