Well I almost got it home. Right now it is at my friend's house as it sprang a fuel leak. The return hose that goes from the driver side head to the fuel pump assembly is bad. Should have it up and running again tomorrow evening. Also found out it is a Centaurus conversion.
I think it is the line itself, my friend watched for the leak while I started it and it is almost like the return line was cut. Also no way I'm giving up on it this early, edit: it's the line that goes from the front of the head to the block on the driver side of the fuel bowl, not to the pump.
