Where to mount amp?
Where to mount amp?
So, going from an 09 to a 12 Superduty Super Cab. Basically the same setup. In my 09 I had an amplified Bazooka under the back seat. Did ok, but I was thinking I would up the quality on the new truck. I was considering an MTX Thunderform. They come amplified or not. I have a JL audio Slash sub amp I was planning to use and was going to order the non amplified Thunderform. Here's the question. I don't have the new truck yet, but I'm guessing it's the same as my 09. If that's the case, where can I mount an amp? Under both front seats are heated seat relays, power seat motors, etc. Under the entire back seat would be the sub. I got my hand up behind the rear seat back rest and that's all full of spring supports. So, am I stuck? I guess I could get the amplified version, but I'd rather use my high end JL amp rather than MTX's cheap built in version. Any ideas would be appreciated....
You think? I managed to get my hand up there and it seemed tight to the back wall with spring bracing everywhere. Will have to look further. If I had a reg or crew cab I know there would be more room. I suppose if all else fails, I can just put it at the bottom of the center console.
nut1605
09-22-2006 12:37 AM
1yamman350
01-25-2004 11:12 AM
StRanger302
09-05-2003 07:32 PM
pompiselefante
03-31-2003 02:10 PM
